SOURCE: Flip Video Problem with deleting videos
What you guys need to do is empty the trash can on your mac before you eject the camera if you are deleting videos from your computer.
SOURCE: Lost record time due to corrupted video files
I have the same problem....someone please post solution!
I've tried systematically deleting each of the database type files on the Flip (while keeping a saved copy on my computer hard drive). This doesn't seem to help. I've just got one minute of video it will allow me to shoot!!!!!
SOURCE: My Flip video Error code 17,2 - won't connect to software
Tech Support at least found a solution to upload.
Remove the battery from the Flip, then insert into PC. You may have to manually uninstall the driver association during the previous hardware failures (Use Control Panel, Device Manager, Hardware, USB Devices - then right click the yellow ? icon to uninstall).
If you are lucky, you will now see your videos. Upload to your PC, then insert the battery pack while connected. Unplug the Flip, wait 10 seconds, and try again.
If this solves your problem, charge by connecting to a PC for 6 hours to make sure you have a full battery charge.
SOURCE: Can you Recover a deleted video off the camcorder?
The answer is YES. Do it as follows.
First things first: DO NOT take any more videos with the memory card or hard disk (on your camcorder) that you want to recover videos from. Take the memory card or disk out of your cam and put it in a safe place. Because if you take any more videos or save any data to your memory card or hard disk, you may quite possibly ruin your chances of video recovery.
Then Connect the card or disk to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a data recovery utility that will recover your videos with Wondershare Recovery Software (I once used this program bounded with some other software) from the following link:
Video Photo Recovery (if you are running Windows OS)
Mac Data Recovery (from MacUpdate site)
Remember - Do NOT try & write anything back to your camcoder(card or disk) until you can recover your videos safely!
SOURCE: Can you Recover deleted video off the camcorder?
The answer is YES. You have chance. Do it as follows.
Next, if you are comfortable with using a PC then you can download a data recovery utility that will recover your videos with Wondershare Recovery Software (I once purchased this program bounded with some other software) from the following link:
