I had the same problem for four years until I purchased a CD from Ebay titled "BMW E30 Convertible". I discovered, that I was opening the top up incorrectly. The top works fine. Unlatch the top from the windshield frame, then lift up the back half of the top, unlatch the top lid, rise it up and lower the top into the compartment, close and latch the soft top lid.
Hopes this helps.
For the fact that you don't know what is the cause as you bought it like that I think it's best for you to buy another gearbox before you start spending on that gearbox, then you can start deciding on fixing selling or keeping it for spare parts bye bye
ok sensor I is located at the right of the top side oil filter, and sensor II is located to the very front right corner of the engine, they should just turn out like a bolt, diconnect the wires first of course and then tunr them out and replace then, make sure to put anti seize on the threads when installing new ones, reconnect wires and test again.
I have this very same problem. When i try to start ot after it warms up i just get a wirling sound. After about 2 hours when it has cooled down it will start fine. The problem is the starter motor. The solinoids exspand when hot and lose contact because of the heat fom the engine. This is a classic starter motor problem when they are on their last legs. The only other thing it could be is the brushes loosing contact. Either way just replace the starter and it will be fine.
Sounds like the sensor has faulted or the pump has become disengaged. Usually when the light is flashing it's a sensor. You can check for a pinched line or low fluid also. There is a manual lock overide procedure to get the windows up, it's in you owners manual. Good luck...i hope this helps,
remove steering wheel (17mm hex nut) remove screws from dash cluster(3 on bottom. 2 on top) Unplug connections to cluster Tilt towards you and pull up, and that it! Trust me , you want to take the steering wheel off , makes the job much easier!
contact BMW help desk tech office pick there brains. do it yourself if you can. or pay someone. I not got BMW but thats what I do start at the top work down. ask expert and they make um. liz
