Question about Casio Forester FT500WV-3BV Wrist Watch
Casio 2312 what battery is appropriate
What is battery for casio waveceptor 3747
CASIO module 3747, battery CR1620
Apr 09, 2017 | Casio Watches
How to change the battery on my casio w-753 watch
change the battery on my casio w-753 watch Lee, Check the attached links,video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
replace the battery in the watch casio 753 CAR FLIP REMOTE CONTROL ALARM...
How to replace the battery on Casio watch
CASIO 753
Aug 02, 2016 | Casio W753-1AV Watch
Casio sgw 500 the compess reading is very wrong
You have to calibrate.For that, go to your manual appropriate section and follow the procedure.
Mar 04, 2016 | Casio Watches
Operation Manual in English for Wave ceptoe 4771 is not available.
Did you use this link with the appropriate module # on the back of the watch?
http://world.casio.com/wat/download/en/manual/
If you did, and still couldnt find, then you will need to contact CASIO at the following link:
https://www.casio.com/support/contactus/contact/
Aug 16, 2010 | Casio Watches
How do i turn the time back on my casio wave ceptor 4756
Press the lower left hand button until the display shows "HS"
Use the upper or lower right hand buttons to adjust the hands in the appropriate direction.
Jan 01, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I put in new battery using Casio instructions but still does not work. Touched battery and ac with tweezers for a few seconds, nothing happened?
Make sure your new battery is not flat and on full power. Sometimes batteries are not fully charged as they discharge over the time and as they are stocked in large quantities, some of them get discharged even they are sold as brand new.
When replacing battery in your watch, make sure you keep the right polarity. Plus and minus must match appropriate contacts. After replacement connect AC and plus side of the battery at once for 2-3 seconds - this will reactivate watch and you will need to set the watch manually.
If you did all this and your watch don't work at all, there is some fault in watch mechanics and you have to look for watchmakers help.
Jul 09, 2009 | Casio Watches
I have a Casio DBC-60. I changed the battery because was not working for long time, but the watch stil is not working
This is an old problem, but maybe this will help someone changing a battery on a Casio. Many Casio watches must be "zeroed out" by putting an pointed tweezers between the back of the battery and the AC terminal off to the side of the battery. On my old Casio Telememo 50, the AC terminal is in a very small hole just above the battery. On the Baby G force, it was in a wider opening, way at the edge of the watch. It has something to do with resetting the watches circuitry so it will operate again. Good luck!
May 14, 2009 | Casio Watches
Battery replacement for casio wave ceptor wvq-200hu WATCH
Download abridged instructions from casio @ http://world.casio.com/wat/download/en/manual
Apr 05, 2009 | Casio Waveceptor Atomic Radio Controlled...
Casio Illuminator
I used the online CASIO web site to locate the appropriate manual and followed directions. Use the bottom left (C) button of the watch to keep pressing between the various modes until I was in the ALARM Mode. Then PRESS the upper right (B) button to toggle the DAILY ALARM and HOURLY CHIME to "OFF", "DAILY", "HOURLY" and "BOTH" on/off.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1950.pdf
http://support.casio.com/manual.php?rgn=1&cid=002
Jan 17, 2008 | Casio W94HF-3AV Wrist Watch
Casio Forester FT500WV-3BV Wrist Watch Logo
361 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
