SOURCE: Akai TV Stuck in Video Menu Page
Unplug TV for about 2(two) hours, while the TV is unpluged press the on\off button on the TV every once in a while. Replug electricity and try to turn the TV without the r\c, use the on\off button only...If that does not work...u need a tech to look inside..
SOURCE: Screen goes black after 2 seconds
This is a mean problem, and I feel for anyone who has it.
This can be caused by a bad power board, a bad main board or a lcd LCD panel.
An authorized repair shop would be able to substitute the main and
power boards to find the source of the fault, but you don't have that
luxury.
Unless you want to risk paying for an expensive part you don't need, I would suggest you take it to an Akai repair shop.
SOURCE: akai lct 2701td comes on then shuts down
Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2701AD POWER SUUPLY MLT166A
Thanks
GEORGE
SOURCE: akai flat screen lcd tv.. turns itself off after about 10 min
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty
was Expired) and found several faulty capacitors on the PSB. Its
pretty common. Major Electronic companies were sold faulty capacitors
that fail in 2-5 years instead of 10-20 due to a lack of
preservatives. It wouldn't surprise me if you have the same problem.
TV will work fine for a few years and then just fail completely or
slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
