Computers & Internet Logo
A
Anonymous Posted on Jan 24, 2013
Start my panasonic CF-f9 in safe mode. what key do I press??
What key do I press to start in safe mode
Richard Eckerlin
Level 2:
Novelist:
Scholar:
  • Panasonic Expert 123 Answers
  • Posted on Feb 18, 2016
Richard Eckerlin
Panasonic Expert
Level 2:
Novelist:
Scholar:
Answers
123
Questions
0
Helped
54426
Points
209
For ALL Panasonic Toughbook Models
and for all Operating Systems
(Win XP, Vista and Win'7):
To start in safe mode, press the "F8" function key
(located ABOVE the number 7) immediately and
repeatedly as soon as you power-ON your
Panasonic Toughbook model.
You will see three choices in a text-only Windows:
Safe Mode (without networking)
Safe Mode with networking (my regular choice)
Safe Mode with Command Prompt
Use the UP or Down Arrow Keys to HighLight
the selction and then press Enter to choose.
That is it!
Good Luck,
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
5 Related Answers
Anonymous
  • Posted on Nov 20, 2008
SOURCE: Panasonic CF-48 Laptop has screen problems
hallo iam sudeep kumar from kerala.please helpdisplay driverpanasonic cf48
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Jun 22, 2011
SOURCE: asusEee pc:everytime i turn on
Hi this is usually a corrupted driver usually a Video driver, but not always, it can sometimes be the harbinger of doom, and it may indicate that the HDD is going/gone? faulty.
Now what you may need to do is to perform a boot from a recovery CD/DVD or Boot from a Windows DVD, then either perform a system restore, or indeed a factory restore.
usually though, whenever there is a minor problem it will not continue to reboot as it is doing now.
In this case I think that you will have to attempt recovery from the USB port, please look at the link below, this will show you exactly what and how to do it all. You will need access to another PC to make the tools required to do the job.
http://myeeeguides.wordpress.com/2008/10/15/eee-pc-1000h-recovery-from-usb-flash-drive/
Another way below...
http://wiki.eeeuser.com/restore_1000h
pankaj_dic
pankaj rautela
  • 1252 Answers
  • Posted on Jul 27, 2011
SOURCE: I get the startup screen
have you check last known good configuration or windows restore option
CreativeTECH
Creative Tech
  • 1719 Answers
  • Posted on Oct 14, 2011
SOURCE: What,s the safe mode button for a Panasonic
Press F8, at system start up to choose safe Mode.
(It is F8 for all the Systems with Windows Operating System)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Jul 03, 2012
SOURCE: panasonic cf-51 bluescreen unmountable_volume
Run hard drive diagnostics: http://www.tacktech.com/display.cfm?ttid=287 (or http://www.bleepingcomputer.com/forums/topic28744.html)
Make sure, you select tool, which is appropriate for the brand of your hard drive.
Depending on the program, itll create bootable floppy, or bootable CD.
If downloaded file is of .iso type, use ImgBurn: http://www.imgburn.com/ to burn .iso file to a CD (select "Write image file to disc" option), and make the CD bootable.
You could also try a Live Linux like Knoppix Live from here:- http://www.knoppix.net/get.php,
download the Free ISO using a Torrent, burn it to a CD then run that it will load into Ram and then ith all the software in the CD you can examine the hard drive
hope this helps
2answers
How do you get out of safe mode
go to the start menu choose run if you don't see run hold windows key down to the left of the spacebar then press r key.
Fill in msconfig click on boot.ini make sure safe mode in unchecked
Terry
Put panasonic cf 29 into safe mode
On ALL Panasonic Toughbooks you can
boot into safe mode as follows:
Make sure the Toughbook is OFF.
Power on the Toughbook and immediately
start to press repeatedly the "F8" function key
which is usually located above the number 7 key.
You only have 2-3 seconds to do this and this
will only work in Windows XP, Vista or Windows 7.
A "text-only" screen will come up. You can then
choose SAFE MODE or if you also need to
connect to the internet choose:
Safe Mode with Networking.
Use the UP or Down Arrows to highlight the
selected option and then press Enter.
That is it.
Good Luck!
Regards,
2answers
My laptop cant boot normal to w7
app laptop up key F8 AND F9 click to automatic boot
Fn key
You could map that FN key to another unused key in Windows such as use the "[" or "]" key mapped as FN. Requires DOTNET Framework 2.0 to operate.
http://download.cnet.com/microsoft-net-framework/3000-18513_4-47206.html
http://mapkeyboard.inchwest.qarchive.org/
if no joy try it in safe mode
restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode
restart your computer press and hold the delete or f2 key to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
or
hope this helps
Boot CD to format
Hi
Insert the installing disc.
Power off the machine.
Power it on and press F9 until the 'boot from' option appears.Select on CD and press enter to start the boot.
Solved?
What,s the safe mode button for a Panasonic toughbook CF-25
CreativeTECH
I have an HP mini and it has a virus. The only option at start up is F9 and F10. How do I get to safe mode?
To get to safe mode when you press power button to start the computer you have to start pressing F8 key but don't hold it instead keep on tapping it and this will bring you to Advanced menu options and here you can choose safe mode. IF this does not work there might be issues that are preventing this from happening which usually involves hard drive issues.
Hope this helps.
1helpful
How do i turn my laptop in safe mode
Press power button and press F8 repeatedly until you get the black screen offering option to boot the system into safe mode.
CreativeTECH
I forgot my password for my panasonic tough book cf-73,what can i do
You could go into safe mode and change your password, you can do this by tapping f5 key when system is starting up, then go to your control panel then into user accounts. Just make sure you are logging in as the administrator.
If your not running windows xp you will have to tap f8 when starting system for vista.
Hope this help. :)
1helpful
When I start my panasonic toughbook all I get is the panasonic name and then a blank screen
Try to reset hardware first:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
If it remains same, restart and tap F8.
If you get an menu, select safe mode and press Enter
See if it able to start in safe mode.
Top Panasonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
