E-Machines W3400 PC Desktop Logo
Posted on Jan 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Front panel connection
Front panel to the motherboard is disconnected. control on and off. need to know where the wires connect to. its a howard computer model # E3600.
Dana P
Level 2:
Sergeant:
  • Expert 206 Answers
  • Posted on Jul 19, 2010
Dana P
Expert
Level 2:
Sergeant:
Answers
206
Questions
0
Helped
39535
Points
533
Http://www.fixya.com/uploads/images/284ECAC.png
Anonymous
Level 1:
  • Contributor 21 Answers
  • Posted on Jan 28, 2009
Anonymous
Contributor
Level 1:
Answers
21
Questions
0
Helped
7732
Points
36
Try this : See if you can find your motherboard model number. If so, type it into Google, go to the manufacturers site and download a manual which should have the wiring diagram you require.
Cheers.
1helpful
2answers
Transferring motherboard from Gateway SX2801-07E to another case. How do I connect the motherboard front panel headers?
  1. Identify the headers: Locate the front panel headers on the new case and on the motherboard. Make sure that you have identified the correct headers and that they are compatible with each other.
  2. Check the pinout: Refer to the manual for the new case to determine the pinout for the front panel headers. Make sure that it matches the pinout listed for the motherboard, as mentioned above.
  3. Connect the wires: Use the pinout information to connect the wires from the new case to the appropriate pins on the motherboard. Make sure that each wire is securely connected and that there are no loose wires that could cause a short circuit.
  4. Connect the HDD LED: The HDD LED can be connected to pins 13 and 14 of the front header (LEDH1).
  5. Connect the power LED: The power LED can be connected to pins 3 and 4 of the front header (LEDH1).
  6. Connect the reset switch: The reset switch can be connected to pins 7 and 8 of the front header (LEDH1).
  7. Connect the power switch: The power switch can be connected to pins 10 and 11 of the front header (LEDH1).
Make sure that you connect the wires correctly and securely, as an incorrect connection can cause damage to the motherboard or the front panel components.
7helpful
2answers
MSI PM8M-V Motherboard front panel wiring problem. Need manual for connectons diagram to connect frontpanel audio wiers and make check-up for other connections. Didn't found the manual from msi...
You can download it from HERE, the manual is inside that winzip file as a pdf file. And the details about the Front Panel Connection is on page no. 24 of the Manual. Here's a screenshot for you:
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
I need assistance with the front panel cables for Intel d915gav. My computer wont turn on. I dont know where to connect the connections. & I dont know why my computer wont turn on. Please help, I need...
Follow this link to the spec sheet for the board. Make sure the wires running from the inside of the front cover are plugged into the correct pins.
http://downloadmirror.intel.com/15196/eng/D915GAV_D915GAG_TechProdSpec.pdf
10helpful
2answers
Problem with panel front conector in Dell Dimension 2200 motherbo
The following information is to assist you in performing the right connections. You should take precautionary measures such as grounding yourself and completely disconnecting the PC form any source of power.
This picture shows the connector for the front panel power button, reset button, and power and hard disk lights: an 8x2 pin connector with 1 pin missing:
The table below lists the pinouts for the connector. The orientation of this table is the same as the picture above, this shows the top part of the connector. All the pins below pin 8 appear to be non-connected.
Each pair of pins labeled Power and Reset goes to the 2 wires for the corresponding button. The hard disk and power LED wires connect to the corresponding LEDs, you need to ensure the proper polarity of the + and - wires for each LED or it will not illuminate.
The above information is for your information only.
Hi . I have foxcon 760gxk8mc-rsh motherboard and i disconnect all wires.I connected most of it and only don't know where I should connect power sw and reset sw( in which pin)
If you do not have you're manual for the motherboard open the link provided below and download it; http://www.foxconnsupport.com/download.aspx?models=en-us0000190&category=C000000001&series=en-us0000003&keywords=&sort=Motherboard
You will also need to download and install Adobe reader in order to view the manual. Download Adobe form the link; http://www.adobe.com/products/reader/
Open to page 4. This is motherboard layout.
Turn to page 13. Here you'll see how to connect the front panel, [FP1] jumpers. The wire colors define which wire is positive and which wire is negative. Each set will have a common color. This common color will be used as negative.
Cheers'
Mike
2answers
Front Panel help for Dell Dimension 4600
Go to dell site and query for *********** board specs. Then query for the pinouts on the board. Or goodle dell optplex+motherboard+hardwire connections. good luck
Is It required to connect Tower Front Panel I/O to Motherboard
The power button on the front panel would definitely need to be hooked up to the motherboard so you can power up the computer.
If you have any usb slots or a media card reader on the front panel, or both, then you would need to hook those up as well, otherwise the main one you need to connect would be the power button.
3answers
Wiring
give me your email. I will send a picture of Front panel connections. BTW are you a tech or feel comfortable to T/S further?
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Connecting the wires
>>>>User Manual Download<<<<
Here is the user manual of your MB. Look for ports and were to connect cables. The more hard are those little cables from the front panel chassis. Take a look and you would find the right combination. In computers everything goes one way just don't try to force anything. Let us Know....
Front panel hook up
HEY MAN U HAVE SERIUS PROBLEM... OK THIS MAY SOLVVE U R PROBLEM....JUST DOWNLOAD U R MOTHERBOARD USERS MANUAL...AL CONNECTIONS ARE GIVEN THERE..EVEN FRONT PANAL SETTINGS TOO.... BEST REGARDS MAIL ADD- [email protected]
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
