When i connected to the computer i received message saying restore your ipod to factory. i did so so later stopped to be recognized by itunes
Connections b> The USB cable must be securely connected both to the iPod and to the selected USB port on the computer. Reattach the cable at both ends, and click "Computer" in the start menu to see if the iPod is shown connected to the drive for that USB port. b> Drivers b> If the drivers of the computer responsible for the USB interface are out of date, malfunctioning or incorrectly installed, that may also cause the iPod to not be recognized by the computer. If this is the case, the device may not appear in iTunes and there may be an exclamation point next to the device in Device Manager. b> Software b> The latest version of iTunes is recommended to best communicate with the various models of iPod. Go to the iTunes website or click "Help" and "Check for Updates" in iTunes to install the most recent update. Further, the computer must be running Windows XP, Vista or Windows 7 for PCs, or OS X v.10.4.11 or later for Macs. b> Battery b> The iPod's battery must have sufficient charge to be recognized in iTunes; charge it either via USB connection or another power source if the indicator shows a low battery. Once the battery has charged, try to connect the iPod to the computer via USB cable again.
http://support.apple.com/kb/TS1538 Ipod not recognized http://support.apple.com/kb/TS1495 Device not recognized
SOURCE: ipod 30gb help
http://www.apple.com/itunes/
TRY HERE FOR THE LATEST VERSION OF ITUNES AND IT WILL HAVE THE LATEST DRIVERS FOR YOUR IPOD TOO.
ONCE YOU HAVE DOWNLOADED IT CONNECT YOUR IPOD AND ONCE IT IS RECOGNISED IN ITUNES GO TO THE OPTIONS FOR YOUR IPOD AND RESTORE IT FROM THERE
SOURCE: My Computer and iTunes does not recognize my iPod
The best solution to fix this problem is really simple. Only works on Ipod Nano or any other Ipod [Except Touch And Shuffle]. All you gotta do is:
1. Keep Ipod with the usb cable connected to your computer.
2. Reset your Ipod by pressing the round button and menu button at the same time and hold it for about 3 to 5 seconds.
3. After the Ipod reset is complete it should show the icon or itunes should pop up with the icon and your done. Works almost 100% of the time.
hold down the middle button and the Menu button until the apple icon came up on my iPod. At once, the iPod icon returned to my desktop AND on my iTunes window. Works great now. Just like nothing happened.Good Luck!!!!!!!
SOURCE: 8GB iPod Touch Disabled
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Plug the
usb cable into the Ipod and NOT into the computer.
Hold the
Home Button down for 5 second (do not release it)
Then
Press and hold the Power Button for approx 10 secs (count them out)
Your iPod
will reboot.
Release
the power button and continue holding the Home button for an additional 27secs.
You may
see the screen go blank or not.
Plug the
USB end into the computer with itunes open.
Your ipod
will mount in recovery mode.
Restore
it and Your all set.
if you need any further help let me know.
Good Luck
SOURCE: Ipod wont connect to computer or itunes
slide the hold button on and off a couple of times and then let it rest in off position and press and hold menu and centre buttons till a silver apple logo comes.the connect to system and it should be detected by itunes in recovery mode.restore and you're done.
