I used the micro last night and it seemed to stop before the time required to dethaw hamburger. I did not try again, just removed meat and continued to cook on the stove. I tried to heat milk this morning and there is no power. No lights, no settings work etc. I removed it from the wall, and tested the socket. It is fine. I cannot see if there is a fuse or reset button.
Please follow this steps and fix it. God bless you
Line Fuse
Every microwave oven has a line fuse. This fuse is designed to blow if too much current is drawn through the microwave circuitry. The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
Main Control Board
If the microwave is not working the main control board may be defective. This is not common. When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Thermal Fuse
If the microwave is not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
SOURCE: microwave stopped working last night
If the microwave worked for a little while after you plugged it in again then it is just overheating.It is usually just dust/dirt collecting on the vents.the fan,and the magnetron(the thing the fan blows on).If cleaning all these doesn't solve the problem you may have a bad high temp overload sensor,and need to replace it.(this sensor is usually mounted directly on the top of the magnetron.The magnetron is the part that actually puts out the microwave signal.I've never seen a reset button.The high temp sensors reset themselves automatically.
SOURCE: Our Panasonic 1350 microwave no longer heats food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ghdgh
SOURCE: My model nn-p295wf microwave stopped working ,all
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
SOURCE: panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
