Heating & Cooling Logo
George Friborg Posted on Jun 08, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fasdfas My Armstrong 80 furnace will work fine for about 10-20 minutes then turns off before reaching desired temperature. I sometimes have been toggling the thermostat set temperature to get the furnace to kick-on. Furnace does blow hot air. Example: My new thermostat reads 62 but is set for 70 degrees. When furnace kicks on, it only stays on for about 10-20 minutes and increases room temp to 65. I already cleaned the flame sensor which didn't seem to make a difference.
Andy
Level 2:
Habit-Forming:
New Friend:
  • Expert 117 Answers
  • Posted on Jun 08, 2017
Andy
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
117
Questions
Helped
61355
Points
292
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
2 Related Answers
Anonymous
  • 700 Answers
  • Posted on Dec 21, 2008
SOURCE: Furnace doesn't reach desired temperature
On the thermostat if its a manual on then pop the cover off and look for a small dial with numbers on it. Take and move it tpoi a higher number than whats it is set at. Its called a heat anticipater and is supppose to make it so that the unit does not oveshoot or under shoot like what your experiencing. If its a digital oine then you are going to have to configure the setting in the insdtallers menu.
Ken Bledsoe
  • 306 Answers
One of two things you can try. Do you own a volt ohm meter? Anytime your unit cycles short like it is doing the control circuit which on this one is 24 volts that engages relays and controls the gas valve to open and close. I am thinking the heat exchanger is getting so hot it is tripping the upper limit which for the most part is around 180 degrees. So next time it turns off take your ohm meter and with the power to the whole unit off. Either turn the breaker off or there is a light switch that is real close to unit turn it off. Undo the two wires to the gas valve and ohm them out. You should have continuity if you get nothing check each limit switch should have a couple. Undo wires to them and check. If you find one that is open more then likely the upper one. They are a safety device that keeps the unit from getting too hot.
There might be another option increase the speed of your fan motor to get the heat out of furnace quicker. Look at the circuit board notice the fan wiring going to it. The Red wire from fan is low speed look to see if it is on HEAT on the board. You should have 4 speeds to pick from you could take the black off of COOL and swap wires and test the unit by doing that. I'm going to put a solution on this so I can come back to it quicker. Even though we a just testing it for now. ken
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Fan cycles after burner stops
When your furnace has reached desired temperature the burners will turn off but your fan will continue to blow for a couple of minutes Or in other words until it cools your fan limit switch. This switcheck is what tells your blower motor when to kick on and when to kick off.
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Gas Armstrong Ultra V Tech 91-Is green light supposed to flash?
Installed a new filter and furnace is running great now. The old filter was not that old, but we have been doing some remodeling and I figure that is what clogged it so fast.
2helpful
Armstrong ultra sx 80 furnace starts up and runs and then the gas shuts off for a few seconds and then lights backup and causes a small backfire my Ultra sx 80 furnace will ignite then immediately turn...
You have a dirty flame sensor. Look at the very last burner and you will see a wire going to a ceramic sensor and it looks like a thick wire. Take some steel wool or fine sandpaper and clean the surface off and it will work like a champ.
Let me know how it goes ken
2answers
Top Heating & Cooling Experts
Paul Carew
john h
