SOURCE: I lost my cd
Go to www.kyoceramita.com and you will see a download centre. You can download the driver from there.
SOURCE: Kyocera Printer error - Help!
The code is for a defective cyan motor. So its either the cyan toner motor or a lump of toner inside the cyan toner container.
SOURCE: Kyocera FS-C5030N KX firmware update tool
you are overcomplicating it... all you need is a compact flash card big enough for the firmware... then you upload the firmware to the card and stick the card into the printer... but first power down printer and plug it out and then turn it on and follow the display... it will prompt you
here is the steps...
you will see ready
then press menu... arrow down to memory card
press forward arrow
you will see format
press enter
you will see processing
when its finished
you will see ready...
turn off machine... unplug it...
pull out compact flash
plug machine in
turn it on...
the **** for the compac flash is on the right hand side at the bottom by the ventillation opening...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: Kyocera FS c5030n paper comes from the from back
close the back cover... or if its broken tape it down...
SOURCE: Kyocera FS-C5030N. When i print all i get is black
the charger is broken...
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
Reinsert the connector. Also check for continuity
of the connector cable. If none, replace
the cable.
