Im trying to connect my pogo via blue tooth it pairs but will not connect. ive tryed restarting both my phone and the printer & tryed the pogo app. i have an android Lg optimus 1 and i know it work because i printed a picture with it before but as soon as i tryed a second one it wouldnt work.
Teri,
I can't explain why this might work
but try this.
Disconnect the speaker from the phone's blue tooth by unpairing it
then reconnect the speaker by pairing it to the phone again for a fresh reconnection via blue tooth..
Had this issue with a Jabra blue tooth speaker on my wife's mobile phone was doing the exact same symptoms !
It was very very annoying but doing the pairing again fixed it .
Please follow the below steps, i hope your problem is resolved :-
Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
Switch off the bluetooth and restart it , so that it's ready to accept new connections.
Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
If the above method does not work , sadly your phone does not support the Jabra blue tooth.
You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
Hi, you will need pair both phones together before you can be able to send .
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
when printing make sure that the paper is inserted in the pogo shiny side up and logo facing down. also try putting through the blue alignment sheet first as the pogo will not work without this. hope this helps
No printer driver needed. Just establish a Bluetooth connection between the PC and the PoGo, then send the file to the PoGo using Explorer. In Windows you can right click on the JPEG file and send to - bluetooth device.
