It will scan from printer to computer and scan from computer to printer but will not print from computer to printer
Dear Friend
if you want to your printer print over wireless you should setup your printer with your internet modem just if you have original CD or DVD install from it if you don't have install the driver from the website for example HP printer type in google (download hp printer (model like) 2150 etc and just enter go to site and download the driver when you install the driver it will give you 2 option first install the driver with USB and the second option is install wireless driver you just click on wireless driver then type the network name (like tplink, stc etc) of your wireless and password the next and finish hope this will fix your problem
2nd option is take the Lan Cable and connect the cable to the printer and the modem go to control panel and install the driver from the control panel click on sound and devices and click on add printer then the computer will automatically find the ip and name of printer just install it hope this answer will fix your problem
You have to make sure the router recognizes the printer and you have the wireless driver installed on your computer.
SOURCE: HP photosmart C4385 scanning problem
Ok - the reason this error pops up is because there is a software issue going on. If the software is correctly installed you will see options for where the scan will go in the computer.
Having said that there are several things that can cause a problem between the printer and the software;
1) You are connecting the printer by USB to router - you may print but will never be able to scan as this is not a networkable printer. Connect it directly to your computer and recomplete the setup portion to configure the scanner.
2) You have not finished the setup. At the end of the installer you can setup the scanner but if you skipped this step you will have to redo it in order for it to connect. Click on the device manager in your dock and then next to information and settings there will be a little wheel. Click on the wheel and go to setup assistant. Complete the assistant and try to scan.
3) The printer is not grabbing the new software options - leave the printer turned on but unplug the power cord and wait for 30 seconds. Plug printer back in - when you do this it should initialize and will look to the mac for changes and the options should load.
4) Software missing - You MUST have the software for the printer installed for scanning function. Adobe and other programs cannot replace it - it has to be installed.
5) Software is corrupted. Uninstall the software (uninstaller is under applications in the HP folder) and then download (www.hp.com) and install the most recent full feature software and drivers for your operating system.
6) If all these steps fail you may have an issue with your computer and it's TWAIN drivers.
SOURCE: Can't scan on HP Photosmart C4380 even tho printing works fine
I am sick and tired of the problems i have with this PSC, but i have found a scanning solution and thought i would share it.
Use Microsoft Paint. It's not the best application in the world, but you can insert a scan from a scanner in the 'file' menu. :0) The scans are not of the best quality, but i'm grateful i can scan at all with this useless PSC.
SOURCE: HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
SOURCE: Problems with HP Photosmart C6280 All-in-one Printer
Populate the destination list
You must populate the destination list in HP Solution Center for the
Scan To
function to work. Follow these steps to populate the destination list.
NOTE:
HP
Solution Center is the software that came with the product. You must
make sure the software is installed on the computer for all the product
functions to work correctly. The software is also necessary for
completing this procedure. Install HP Solution Center if it is not
already installed.
NOTE:
It might take several minutes for the list to populate.
If
the appropriate programs are already listed as scan destinations,
discontinue this procedure. You must reinstall the software.
SOURCE: HP photosmart C5580 How scan to computer?
scanning through bluetooth is not possible
bluetooth module only pairs the computer and printer and has link only to the basic driver of the computer
so you can only print from it
if you want to scan you should connect te usb cable or use a wireless upgrade kit
