Garmin GPSMAP 60 GPS Receiver Logo
Jon Thompson Posted on Jul 24, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not acquiring satellites
My GPS map 60CSX is not acquiring satellites. It was working fine until most recent power up.
  • gcreeper Feb 11, 2009
    i have the same issue stuck on aquiring for hours on end tech said it has to go threw and gather almanacs/ ./?? for 5 HRS just bought it first use and bleh not working worth ****....... hELLLPp
  • kapil1978 Feb 12, 2009
    reloaded the software to the latest available through webupdater. But still it gets stuck on "aquiring satellite" can someone help?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1720
Points
Perry Mellott
Level 2:
  • Expert 147 Answers
  • Posted on Jul 24, 2007
Perry Mellott
Expert
Level 2:
Answers
147
Questions
Helped
79019
Points
339
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
My Garmin 60csx won't locate satelites
take a look on the old messages and You will find a solution posted for me.
Gps 60csx don't get satellites signal level
use the webupdater and replace GPSChipsetTypeG file.
Kind Regards,
Silva.
My device has seemed to have lost its ability to acquire satellites. Any suggestions? It's Garmin GPSmap 60CSx. Thanks.
I would try a reset and firmware update first. To Reset the unit hold the Page and Enter keys down while you power up the unit. hold them down until you get a prompt asking you if you really want to reset.
Garmin has a free software called webupdater. this will put the latest software in your unit. If there is a GPS chipset software available please apply that also. It will be in the list when you run webupdater.
You may want to try an external antenna also to see if an internal connection came loose.
Trouble with a gps map 60csx the gps is acquiring sattelited an
Update/Reload your unit's GPS and sytem software via Garmin page or use Web Updater. Your unit will be functioning again. This problem also occurs if you leave your unit on a dash board in a car and it is exposed to hight temperature.
Not acquire sattelites
place the GPS outside with a clear 360 degree view of sky or as much of the horizon as possible and leave it for a few hours it needs to download the almanac from all satellites before doing this
from the Acquiring Satellite page press menu and make sure that the topline of the menu reads "Use With GPS off" if it reads "Use With GPS on" (this means it will not find any SAT's ie for indoor use) press enter to turn the GPS Receiver on
6helpful
3answers
Garmin 60CSx - Cant find satellites
Try a re-load of the chipset driver. It is available from the Garmin website. I find that it occasionally becomes corrupt.
You can check by entering the "Main Menu" then "Setup" then "System" then press Menu and choose "Software Version".
If the "GPS SW Version" is 0.00 then a reload of the chipset driver will correct the problem.
Cheers.
11helpful
9answers
Garmin gpsmap 60csx won't acquire satellites
I found the solution that fixed my 60CSx. You need to make sure you have the latest chipset installed on your device. Go to
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00422-00&cID=145&pID=310
and download the chipset type G ver 2.9.
After you have loaded it on your 60CSx, you should be good to go. Just turn it on like you normally do and now you'll see your device retrieving locks w/ the satellites.
Let me know if this helps you out.
Charles
4helpful
4answers
Go to the Garmin Web site's home page, avoid staring to long at the hot chick and click on "On The Trail" .. "Mapping Handhelds" .. scroll down to the second row far right and click on the 60CSx. You will then see the 60CSx page, look to the right and click on "Updates & Dowdloads", on doing so you will now see four downloads to choose from. The one you will need is "GPS Chipset Type G Ver. 2.90 as of Nov 27, 2006" if you follow this you shouldn't have any problems. If however you do i'll keep an eye on this page and try to help, this is my first GPS and also had the same issue.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
