I set temp to 350 but oven will not heat up to desired temp but I do hear clicks as if the oven is heating up. What could be wrong?
You probably have a burnt out or shorted out lower bake element in you r lower oven. it sometimes will actually break apart or look like it sparked thru the black tubular section. it is common and will cause no heat during the bake cycle.
you could try to do a broil and see if it gets hot and that would let you know the control is ok and just needs the lower bake element.
Thanks for the helpful response. In the bake mode, if I set the temperature to 350 or more, the oven will heat up to 275 but it will take a very long time to get there. However, it won' get any hotter. The broiler seems to work okay.
