Kobo E-reader Touch 2gb, Wi-fi, 6in - Silver Logo
Kathleen Posted on Jan 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ejecting After my e-reader is charged, I don't know how to eject it.
Anonymous
Level 3:
Brigadier General:
  • Master 3,614 Answers
  • Posted on Jan 23, 2013
Anonymous
Master
Level 3:
Brigadier General:
Answers
3614
Questions
24
Helped
1009608
Points
10054
Please give us some more detailed information about your posted problem here.
Disk won't eject
Normally all readers have a mechanical system that can be accessed from the front or the back of the reader to open using a small tool. Normally it's a little hole (like on smartphones) where you can insert a metal piece and push on it to eject the drawer.
Eject SD card
Press the SD card and it will eject out.
2006 Grand Vitara 6-Changer CD Player will not eject cds. 'Push Eject' error comes on.
this is a longshot, try unplugging it, wait about 30 seconds and plug it back in.
2answers
Where is the open/eject button on a Dell Optiplex GX280 Desktop?
I don't know what Eject Button you are talking about, if you are talking about CD tray Eject button then below is the picture which can help you to find it.
I am constantly receiving this message with a micro 2 GB cruzer, "The disk was not ejected properly. If possible, always eject a disk before unplugging it or turning it off. To eject a disk, select...
I have just experienced this problem with e 32Gb ScanDisk card. Every 40 seconds it dismounts with "The disk was not ejected properly. If possible, always eject a disk before unplugging it or turning it off." and the automatically remounts itself.
The card was formatted in my Canon camera and works fine, I also can read the files with iPhoto from the camera, however with a LogiLink card reader it has the above described problem on my MacBoook Pro with MountainLion OS.
Its about time Apple that you researched and found a solution!!!!
Hans Steller
Can't eject disc
if you don't see a hole for the emergency eject even after you open the door, you may have to go online and download the driver to be reinstalled.
2answers
Bose 321 II dvd drawer won't open, fixes here & elsewhere not working. I put in a recorded dvd. It tried to read it, & never gave me the not supported msg as I started trying to eject it...
Hi Donna,
Please do be frustated.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage).
If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
Best luck,
Jay
I just uploading the data from my laptop to my micro sd card, it's been loaded but after if we unpluged it from laptop & load it in phone then only one Folder sowing the data & rest are...
Try to reformat your micro sd card using your phone, then plug it into your pc to copy files. Don't forget to properly eject your sd card not just unplugging it. If this doesn't work try reformatting it using your pc then properly eject it.
Rpd 552 cd reader problem
Message Possible cause Recommended action
E-01 Dirty disc. Clean the disc.
Scratched disc. Replace the disc.
Up-side-down. Check the disc.
E-02 Focus error. Try ejecting and re-inserting
under normal temperature
conditions.
E-03 Data and focus error. Under normal temperature
conditions, eject and
insert clean, undamaged
disc properly.
E-04 Mechanical problem. Eject and re-insert.
Top Kobo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Kobo Computer and Internet Expert? Answer questions, earn points and help others
