Hi Guys, I fixed my horizontal line problem by adjusting the power adjustments for my RGB guns per your web instructions. Worked Great! The red LED is blinking five times (used to be 8 times but that stopped). What does this mean.
Hi Guys, Looks like your advise took care of the problem. I adjusted the power knobs for each of the RGB guns on my Sony 51 inch projection TV. The color looks great and I don't seem to have the blinking indicator light bugging me any more. I will be sure to suggest you folks to anyone with these type of technical questions.
GREAT JOB!!
Hi, The Model is KP-51WS500
Thanks,
Doug
Any Idea exactly which knob it is? They aren't marked. Do you have voltage output levels that I should work to obtain for each gun?
I decreased the power to I believe the blue and green guns to eliminate the horizontal lines that I was experiencing. Occaisionally during this process the screen would flash bright green and the LED indicator lights would blink eight times. The horizontal lines have disappeared but I now the red LED blinks five times
I think you are adjusting screen volt of 3 guns through a box fixed at front corner near speaker.
Let me explain procedure how to set power ( screen volt) HV Control has 6 knobs, upper 3 and lower 3, check there mark of SCREEN R-G-B.
Room light should be low and cover 2 guns lenses with any thing like paper or book and adjust uncovered gun. now cover this and uncover any one other, same adjustment and do the same with last gun.
Adjust screen volt of all 3 guns up to that level as retrace lines ( horizontal lines) disappear.
now screen volts has been adjusted and tv will not give you 5 times error.
Let me know what you had adjusted before at 8 times blinks?
5 times blinks means poor white balance result.
Please readjust those knobs of power (screen voltage).
what is the model number of TV to provide you info about 5 blinks code in Sony TV.
