Question about Sony KV-32FX20U 32" TV
Sony KV-32FX20U picture has a colour cast
My beloved Sony KV-32FX20U started playing up recently causing me emotional hurt. The picture has a bright colour cast - mostly yellow but also pink or purple at times. The sound is starting to fade in and out too :-( I'm gutted as I detest flat-screens and love my great big beast of a TV and would do anything to keep it going. Anyone has any idea what might be going wrong with it and how I might be able to remedy it? All advice greatly appreciated, Dushan.
    Top Expert:
  • Sony Master
  • 76,171 Answers
Check its video output card [a card directly plugged on to the back of the picture tube] for any loose solder terminals. Re-solder all the suspected solder terminals there, by applying a little more solder to each points. A bad solder point can cause this type of problem.
Posted on Jan 23, 2013
  • Dushan Stojadinovic Jan 23, 2013
    Oh gosh - thanks! I'll look into it and report back.
6ya staff
SOURCE:
MikeNJ1964
Mike Longo
  • 398 Answers
SOURCE: sony tv no pic or sound
Sony error codes usually only go up to 7. If the LED blinks 11 times, this usually indicates that either the clock or data line is shorted and this needs to be serviced by someone with experience with Sony sets.
Posted on Jun 28, 2007
Anonymous
SOURCE: Sony Trinitron KV-32XBR37
Bad Picture tube.
Posted on Mar 06, 2008
fougzki
  • 700 Answers
SOURCE: Sony kv-32sf12 -will not power "ON
Try the 60 seconds unplugging of wall plug in your outlet. Or check your line if this have surge protector. Temporary plug your unit to wall outlet directly. Just check if it still within voltage operating range.
Posted on May 10, 2009
Anonymous
  • 252 Answers
SOURCE: No picture, sound works on Sony TV KV-27V22.
try to adjust the screen. it is located behind the CRT board.(CRT board is the board that attached to the picture tube) you will find a black knob which label screen adjust it by turning the knob.
Posted on Jul 04, 2009
Anonymous
  • 5 Answers
SOURCE: no picture no sound
Forward voltage/current problem....needs a new board....You might try unplugging it for a few hours...If the TV starts you will need to leave it on until it gets repaired or replaced.
Posted on Aug 27, 2009
The picture is greenish
chances are you have a bad tube or bad Video IC on the CRT board that connects to Tube! Look on your CRT Board and replace the video IC first.
Dec 30, 2009 | Televison & Video
Dvd's are playing black & white via sound surround system
Check first your dvd player settings if it is in PAL or NTSC.
Mar 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-24FV12 picture problem
Alright, TV has hardware problem in Horizontal section and I would suggest to set Picture Quality as Soft Mode.
Jun 20, 2008 | Sony KV-24FV12 24" TV
SONY KV-32FX20U
I suspect you crt tube is going and is most likely not worth fixing
There are things you could do a tv service shop could rejuve your picture tube and adjust your screen voltage.
sometimes that does not work
I would start looking for another tv
thanks doctor video
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Blank screen on startup on Sony KV-32FX20U
All Sony sets will stay blank until the circuit is ready to power the tube. If there is a problem detected inside the set, the tube will remain vlack and the standby light will blink. This blinking will repeat a count as follows: Blink count, pause for a second or two, repeat the blink count, etc. Some Sony sets will play for a while then flash off and on. This is usually an indication that the picture tube is starting to fail. In your case, you should see a blink code. If you can update this with the blink count, I can use that info plus the model number listed above to provide a possible cause and the parts required to repair the set.
Dan
Mar 29, 2008 | Sony KV-32FX20U 32" TV
Sony Trintron KV-32FX20U
This is a problem with the "AKB" circuit. There is a problem with the video signal. Are you comfortable changing parts inside the set? If so, please update this. I'll look up the specific parts for this model and post them.
Dan
Mar 18, 2008 | Sony KV-32FX20U 32" TV
KV-32FQ75E colour loss
Go to the Sony website and check out the correct antenna cable and scart lead configuration for your set up. I did and with a few simple connection changes it was like getting a new TV.
Jan 07, 2008 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Sony KV-32v25 low brightness and little color
It's more than likely the tube, my friend. The chances of it being a power regulation problem is kind of remote at this stage of the game....accordianman
Oct 20, 2007 | Sony KV-32V25 32" TV
Monitor colours are only fluro purple & green!
use a 10 ins, speaker magnet to front of picture tube degussing color
Nov 29, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
