Ice machine started making cloudy ice instead of clear ice
I think your machine is not clean enough. Need to start with cleaning mode if it has. If not you can clean it yourself with anti-chlorides.
www.tamutom.com
Cloudy ice happens right after you change a water filter due to oxygen in the water just flush it out or if your unit has a purge valve it may not be working also indicates unit may be dirty
Ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
SOURCE: making ice but won't drop it, then the compressor
You can try and adjust your thickness a bit thicker. If this does not help, your hot gas bypass is not working and the evaporator is not warming. You will need a technician.
