Please, I bought a used toshiba 2060 copier, if I put it on this is what showed on the screen "SLUIT ZIJKLEP BENEDEN" could you please tell me what it means. Again could you show me how to change the language. kindly me mail on [email protected]
SOURCE: Windows Vista Driver for TOSHIBA e-studio163 copier
check my link and go to copier manuals/ Toshiba drivers:
http://checkitright.spruz.net/main.asp?page=dp&dis=848698
SOURCE: Toshiba 2060
1. First of all power off the machine
2. Switch on the machine while pressing 'Print+8' keys
3. Press help button
4. It will show the current code on display
5. Press clear/stop button & then press energy saver button.
6. If another codes exist it ill show those codes also, Repeat step 5 to clear that codes also.
7. Now enter new four digit code & press energy saver button to save the code.
8. Restart the machine
E may, vao day coi co con nho nay ngon lam http://www.freewebtown.com/gaigoisaigon/
unE may, vao day coi co con nho nay ngon lam http://www.freewebtown.com/gaigoisaigon/
saverC:WINDOWShinhem.scr
SOURCE: Toshiba 2060 Copier access code
The machine is not a printer as well. I don't know how the account was enabled but we don't know what to do. Thanks for your help!
SOURCE: toshiba e studio 232 screen shows
is the finisher tray atach and connector plug in? it's possible that the connector was unplugged while the machine was on and an memory error apeared! if so, unplug the copier from power source, plug in the finisher, and plug in the power corde . if it won't work you shall check also if all doors of finisher are closed and if wasn't broken one of the sensors!
SOURCE: Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
