I need help to set the multifunction dials. I actually have a Fossil BQ8795. I can set the date dial, but not the day or hour. I managed to misplace or throw away the manual taht came with it a few years ago.
Thank you for contacting FixYa.
Multifunction watch:Pull the crown out to position No. 3, turn clockwise to go to hour and minutes hands; the small dial showing days of the week will move, and the 24-hour dial will also move correspondingly.To set the date, pull the crown out to position No. 2 and turn clockwise until you have set the desired date; push the crown back to position No. 1.
Use this link and browse through my TIPS AND TRICKS:
http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch there.
Actually there is no instruction manual for ME1020 available on Fossil website except for how to replace the battery. When you try to match ME1020 model with the available diagrams, there is no match (4 eyes).
To set the time, pull the crown out to the second position. Now set the min/hour hands. Date hand is linked to it so keep rotating the crown till the date is set is set correctly. Now remaining is the day setting. Notice that the day changes every 24 hour mark on the 24 Hour sub-dial, so cross this mark to change the day. Go reverse & again cross the 24 hour mark to get the next day. Repeat this till you get the correct day setting. Now your day is also set along with date & time!
When you pull out crown, there is two positions (clicks), not just one. First click is for day/date quick setting. Second click is for hand setting. Pull the crown out slowly and carefully and you will soon find out both positions.
I bought my bf this watch for christmas... i set it before i gave it to him... it is the me1045
It took me forever to figure out how to set it, and even longer to actually set it. The instructions fossil gives are useless, and the two side buttons do absolutely nothing.
So.. to set the day of the month, you have to spin the knob clockwise for 24 hrs for each day.
So, if it says 2nd, and the date is actually the 4th in the am, you have to spin it 4 times around the face, ie 48 hrs. If you go over, you're screwed and have to go all the way around again which, trust me, takes a really, really long time. Going counter-clockwise will not change the date, only the day.
The day of the week will change with the day of the month. Don't worry; they might not match up at the end. It may be the 4th and say it's monday. That's okay, because, unlike the day of the month, the week days can be turned backwards by turning the dial counter-clockwise.
Remember to take into account whether you are in the AM or PM. PM will require an extra turn beyond when it first switched to the date.
The dials are part of a Chronograph (stop watch) I assume there is a second, minute, and maybe a date function. Usually the large second hand is part of the stop watch on only moves when you start the stopwatch (top right button) push again to stop and reset back too zero is the bottom button. Usually to set or zero out those dials pull out the crown to the first click (also sets date) then push the top button to set the seconds (big hand) and the bottom button to set the other. sometimes you may need to pull the crown out to the second click (also sets hour and minutes) to set add'l dials.This is generally how you set most chronograph watches the button you push and what moves may be different.
I looked at a picture of the watch. I see the date. the dial that is right below the hands is a moon dial which does the phases of the moon & below that you have a separate second hand. A lot of times on a watch that looks like that if you pull the crown where you set the watch with out half a click it will set the date if you turn it on way and the moon dial if you turn it the other way. To set the moon dial on the watch you need to put it on the full moon when the moon is full again then it will keep up with the phases of the moon. I hope this helps.
multifunction
battery number
