Computers & Internet Logo
Posted on Jan 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My asus p5gc-mx motherboard sound driver cd is missing
Cpu= lga775 socket for intel core duo/pentium
d
chipset: northbridge intel 945gc/ atx power supply
Anonymous
Level 3:
  • Master 565 Answers
  • Posted on Jan 27, 2009
Anonymous
Master
Level 3:
Answers
565
Questions
0
Helped
269811
Points
1490
Killer rig :-) Do you have it connected Raid 0? Yes, here ya go:
http://support.asus.com/download/download.aspx?SLanguage=en-us
This is for XP. If XP is not your OS, then select your OS.
  • Anonymous Feb 21, 2009
    Thanks for the positive feedback and taking the time to vote.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
441
Points
Mother board instalestion cd missing pls update it
Hello, i got maximus formula motherboard. CPU : LGA775 socket for Intel Core 2 Extreme / Core 2 Quad / Core 2 Duo / Pentium extreme / Pentium D / Pentium 4 Processors Chipset : Intel X38/ICH9R FSB...
This is your board by the numbers you supplied:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131199
You have Via P4M900 and VT8237 chipsets and Realtek ALC662(sound)
This is Asus's link for your board:
http://www.asus.com/Motherboards/Intel_Socket_775/P5VD2VM_SE/#download
It's supported to Windows Vista so, it may or may not work with Windows 7.
You can try your sound here, if necessary:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
and, this is Via's link:
http://www.via.com.tw/en/support/drivers.jsp
It appears your board has the support for Windows 7, if that is what you are running so these should be all you need. Let me know if I can help you further.
Dave
1helpful
2answers
Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
Specification the brand , core speed ,socket and core name
Go here for full specifications for this board.
Brand: Asus
Core speed: Supports any socket LGA775 processor. (Intel Core™2 Duo / Pentium® D / Pentium® 4 / Celeron® D Processors )
Socket: LGA775.
Core name: See Core speed above.
Thank You, Come again.
Slasher_X
4helpful
2answers
Mother board
Description: The Asus P5GC-MX is an Intel 945GC Express-based, compact motherboard.Compared to other compact motherboards on the market, it is inexpensive at around $55.This motherboard supports Celeron, Pentium 4, Pentium D, Pentium Dual Core, and Core 2 processors that use the LGA775 interface.This product can support up to 2GB of memory.
Pros: None noted, given available product data.
Cons: None noted, given available product data.
Suitability: A compact motherboard, suited for small computers.
Value: In view of its inexpensive price, this motherboard has great features for the money.
Suggestions: (1) Be sure that you are using a LGA775-compatible processor with this motherboard.(2) If you want to take full advantage of the on-board SATA controller, you will want to consider a hard drive upgrade.Existing IDE hard drives will run on the ATA-133 bus.(3)
XFXg31
General
  • Product type (AE) Motherboard
  • Form factor Micro ATX
  • Width 9.6 in
  • Depth 7.6 in
  • Compatible Processors Pentium Dual Core , Pentium Extreme Edition , Pentium 4 , Celeron , Pentium D , Core 2 Quad , Core 2 Duo , Core 2 Extreme
  • 64-bit Processor Compatibility Yes
  • Mainboard processor socket LGA775 Socket
  • Mainboard / Multi-Core Support Dual-Core / Quad-core
  • Chipset Type Intel G31 Express
  • Data bus speed 1333.0 MHz
  • Storage key information Serial ATA-300 , eSATA port
  • Power connectors 24-pin main power connector , 4-pin ATX12V connector
  • Processor
  • Installed Qty (Max Supported) 0.0 ( 1.0 )
  • Memory
  • Cache Memory Type None
  • Supported RAM Technology DDR2 SDRAM
  • RAM Installed ( Max ) 0.0 MB / 4.0 GB (max)
  • Supported RAM Speed PC2-6400
  • Video
  • Graphics Controller Intel GMA 3100
  • Video Memory Dynamic Video Memory Technology 4.0
  • Audio
  • Audio Output Sound card
  • Sound Output Mode 5.1 channel surround
  • Audio output compliant standards High Definition Audio
  • Telecom / Networking
  • Modem None
  • Networking Network adapter - Ethernet , - Fast Ethernet
  • Features
  • Hardware Features Intel Fast Memory Access Technology
  • Expansion / Connectivity
  • Expansion Slots Total (Free) 2.0 PCI Express x16 - DIMM 240-pin , 1.0 PCI - LGA775 Socket , 2.0 Processor , 1.0 Memory
  • Storage Interfaces Serial ATA-300 - connector(s): 1 x 7pin external SATA - 1.0 device(s) , Serial ATA-300 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s)
  • Interfaces 4.0 x Audio - Input - 6 pin mini-DIN (PS/2 style) , 1.0 x Network - VGA - 4 pin USB Type A , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX - Mini-phone 3.5 mm , 1.0 x Display / video - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Hi-Speed USB - Line-out - Mini-phone stereo 3.5 mm , Microphone - Generic - Mini-phone stereo 3.5 mm , Audio - Generic - RJ-45 , Keyboard - 6 pin mini-DIN (PS/2 style)
  • Additional connectors (optional) 4 x Hi-Speed USB
  • Miscellaneous
  • Included Accessories I/O back plate
  • Cables Included 2.0 x Serial ATA cable , 4.0 x Serial ATA power adapter
  • Software Included Drivers & utilities
  • Windows Vista Readiness Certified for Windows Vista
  • The Intel board is a discontinued product but is a better board than asus
    2helpful
    Cant play gams on this board
    hi...if you want more to run games try to buy a Video card separate..
    if mother board is PCIE slot buy the PCIE Video Card.if AGP Slot buy the AGP Video Card..the best VGA is 512x128 mb..Thanks and Good Luck..^_^
    2answers
    VGA asus p5gc-mx at win98
    Greetings!
    If you are using windows 98, means you have to install the driver individually the different part of your computer like the VGA, sound card, usb, and other attached component, you have to know the model of those parts, so that you know what kind of driver you want.
    I have here a site for you browse and find the compatible driver.
    http://nodevice.com/
    Thanks
    Asus sound driver for dual core processor not working
    now days system has high definition audio drivers they are not installed straghtway, you have to install the service pack patch to invoke the driver, download it from the asus site
    follow this link http://support.asus.com/download/download.aspx?SLanguage=en-us
    Top ASUS Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Paul Bade
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
