Question about Canon XL1S Mini DV Digital Camcorder
Flashing Red Light....
My Canon XL1 is flashing a red light where the Power light normally turns on. What are your thoughts? I've turned it off and turned it back on and even rotated through the various settings and still the red flashing light.
    New Friend:
The flashing "boat" in the middle of the viewfinder just means the button battery is dead. Camera will still work. It's the little pull-out light grey plastic thing that's next to the heel of your right hand when you're using the camera normally. You need a CR2025 cell.
Posted on Feb 23, 2010
I have a flashing red light with a line and + on top?
Posted on Jan 28, 2009
6ya staff
SOURCE:
Wii power light is flashing red
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
Dec 29, 2012 | Nintendo Wii Console
I have a Canon MP210 scanner/ printer that is telling me I have a paper jam but there is no paper in the machine. I've turned off the power and turned it back on, I've looked for a small piece of...
Your printer might be out of paper.. so try this..... press Black/Color button... if it doesn't work turn off your printer and press paper feeder on the back side and press the power button with holding the paper feeder. Don release it until the process of printer is complete... thanks
Aug 26, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
On off light blinkinking from green to red and I
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Dec 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Controller not working
I had the same problem, so I called customer service and had me do this:
1) with the USB cable plugged into the controller, power down the ps3 and turn the on/off switch in the back to "off".
2) hold your thumb down on the front button (where you normally can turn it on) while turning the switch on the back to "on" again. keep your thumb or finger on the front switch.
3) You will hear the normal "beep" that you usually hear when the PS3 boots up, but after a few seconds later, you will hear a secondary beep. Remove your thumb or finger after this second beep and the PS3 will reset itself after a few seconds. I have a projector connected to it, so I had to set the display screen back to HDMI afterwards, but when I disconnected the USB cable the controller worked wirelessly again. The customer service rep said that this allowed the controller to pair with the PS3 again. Note: You probably do not have to have the controller plugged into the USB cable at all while doing this. I just happened to have it plugged in. Hope this helps.
Mar 29, 2009 | Sony Wireless Controller for PS3
Canon xl 1s won't power up. Power light flashes, screen lights up then it turns it self off..will keep repeating like this every few seconds but won't stay on help
Just fixed this problem. It is one of the three main fuses that have blown out. This is not supposed to be consumer accessible or fixable, but I did it.
Open up the camera case using the 5 allen head screws disconnect the top ribbon cable going to the playback buttons on the handle. on the main board (behind the tape deck) are 3 tiny square black fuses The top fuse FU3201 is the VTR The middle fuse FU3200 is the Motor The bottom fuse FU3202 is the Camera/Lense
The bottom fuse was my culprit. I found a tiny piece of copper and bent it into a U shape and slipped it over the fuse so that it touched the metal terminals on both sides and bypassed the fuse. This fixed the problem.
Haven't used the camera extensively since, but shoot about 10 hrs a week with 2 xl1's and will post if anything happens.
Here is a diagram from the Canon XL1 Service Manual: http://www.coycypert.net/files/xl1.png
Here is the service manual download link: http://www.coycypert.net/files/CANON%20DM-XL1.pdf
Feb 20, 2009 | Canon XL1S Mini DV Digital Camcorder
Red & Green Lights keep flashing on Epson Stylus Photo1280
I had the same problem. You need to reset the waste ink counter:
1. Turn printer off, unplug power cord. Disconnect computor interface cable (back of the printer).
2. After one minute, reattach power cord, but not the computor interface cable.
3 Hold down the LOAD/EJECT and CLEANING buttons simultaneously (cleaning button has ink drop on it) .
4 Turn printer on. Release all buttons as soon as the paper out light flashes.
5 Quickly press the cleaning button, and hold for 10 sec while paper out light flashes.
6 Release the button and the printer will initialize.
7. Once the initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on and try to print your document.
This process worked for me. Good luck!
Feb 01, 2009 | Epson Stylus Photo 1280 InkJet Printer
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
Flashing icon
I just fixed mine accidentally... Try this: with Camera on open tape deck, then manually press in the tape cartrige till it clicks in and you hear the tape gears turning then close the tape door last. email me if it works for any of you. lbclassics@gmail.com
Nov 27, 2007 | Canon XL1S Mini DV Digital Camcorder
Canon XL1S Mini DV Digital Camcorder Logo
1,757 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
