you must remove the cluster heres some diagrams to help you. hope this helps, dissconnect battery,then remove ash tray,remove center bezel screws,remove bezel,now remove screws for holdingdash pad behind top of center bezel, pry defrost grill out of dash unplug sensors and set aside,remove screws holding dash pad to defrorst duct and cluster,open glovebox and remove screws holding pad, remove pad,pop out has clips holding,remove screws from cluster pull cluster up and out enough to unhook connector. heres some diagram to help.
