They are not available to the general public as mentioned on their website.
Note: To ensure safety, Bruno products should only be installed by factory-trained Bruno dealers only. Therefore, Installation Manuals are available exclusively to dealers.
This is indicative of a bad flash; I would recommend formatting your USB stick (FAT32), redownload the pkg update (available here: http://esupport.sony.com/LA/perl/swu-download.pl?mdl=KLV32BX300&upd_id=6232&os_id=25 ), and performing a firmware upgrade again.
Taken from: http://esupport.sony.com/LA/perl/swu-download.pl?mdl=KLV32BX300&upd_id=6232&os_id=25
Turn the TV on.
Insert the USB storage device into the USB port on the back of the TV. Note: The USB storage device can only be inserted into the USB port slot one way.
Turn your TV off by pressing the power button on the TV
Press the POWER button again. The POWER indicator will be green for 30 seconds, followed by the PIC OFF/TIMER indicator slowly flashing amber, and the STANDBY indicator is red.
After several minutes, the TV will turn off and then turn back on to complete the update.
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER
INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER
INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off,
the code was entered correctly. If the device does not shut off, repeat steps
3-4, using a different code.
Automatic Programming With automatic
programming, the remote control tests all the codes available on the Code List and assigns the correct
code for the selected device. 1.Turn
off the device with which you want to use the remote control. 2. Press and
hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or
AUD) until the POWER INDICATOR illuminates. The remote control is in
programming mode. 3.Press and
release power button. The POWER INDICATOR flashes once and stays on indicating the
unit is in Power Scan mode. 3.Press
CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on. 4.When the device turns on, press OK
to store the code. 5. Press any
other button. If the device responds, the remote control has been programmed.
If the device does not respond, repeat steps 2-5.
3. Press and hold the corresponding button on the remote control (TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. 1.Turn off the device with which you want to use the remote control. 2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode. 3.Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode. 3.Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on. 4.When the device turns on, press OK to store the code. 5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5. Thanx
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for
about 20mins. Plug it all back in. Turn on the CPU! Also make sure if
your device requires "DRIVERS" or if you have a CD download and install
that before anything.
1. Turn on the tomtom by pressing the power button at the top 2. ones the unit is turned on tap the screen to bring up the main menu 3. Tap on the Blue tool icon 4. the preferences page should open 5. find picture with 3 flags that is the change languageoption
Tap the flags icon to change the language, select english from the list.
You will now see a list of manuals available to
download for your device. YOU MUST have the free download for your computer from Garmin called UPDATER.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
To download the latest unit
software visit Garmin website: www.garmin.com/webupdater After installing WebUpdater once from the Garmin
website, perform all future software updates from your computer. Simply connect
your compatible Garmin device to your computer, then run WebUpdater from your
computer's "Start Menu" by selecting "Start",
"Programs", "Garmin", and finally "WebUpdater"
Normal
0
false
false
false
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
