It spins and washes but still very wet clothes have to turn dial to spin blew down pipes not blocked
DEFINATELY A BLOCKAGE OR RESTRICTION ON THE DRAINAGE SIDE.DISCONNECT THE PIPING COMMING FROM THE DRUM TO THE DRAIN MOTOR. MAKE SURE ALL IS CLEAR. REMOVE PUMP AND OPEN PUMP HOUSING TO INSPECT.(BLADE COULD BE LOOSE ETC). FINALLY RUN WATER INTO DRAIN PIPE AND EXPELL WATER BY BLOWING HARD.IF BLOCKED, RECTIY. REASSEMBLE AND TRY AGAIN.
