This happens more in the evening, even in places that are fine in the AM. Network use related problem?
Losing my mind?
Hi Guys,
This is a problem with the application v8.300
if you are using a map v8.XX or higher you will need to wait for the next appilcation update which should fix this.
if you are using a map vv7.XX or lower, you can remove the 8.300 application from your device and download v7.481 by updating your tomtom again, this will revert your application to an earlier version which you can use until the next application is released.
Hope this helps.
Pabs
Mine stutters, then breaks up, then dies completely! No sound. Switch off and leave for 20 minutes, it works agin for a short time, then same problem appears
mine stutters then dies out completely
Similar problem. My 720 tends to pronounce only part of the direction and/or street name. Then it may work fine again. I have tried different setups with no positive results.
