Only audio out is digital optical
SOURCE: I'm trying to use external
If I am not wrong this tv also has a stereo audio out . have you tried that? RCA audio outt with red and white ports?
SOURCE: panasonic Tc-p42x1 picture is good ,but no sound,
First reset to default, if don't work look for firmware upgrade, then make sure speakers are set to on.Actually there is always digital audio output when there is any TV input. However when the digital TV is used, digital bitstream format is output (for 5.1 channel sound). When any other TV input is used, digital PCM format is output. This is normal and indicated in the owner's manual.
Set the receiving decoder in the stereo system setup menu (not the TV) to automatic digital audio detection, not PCM or bitstream. This will enable digital audio when any TV input is selected
SOURCE: Panasonic hdtv, TC-P42X1, no picture,
Tries tv unplug,replug it back like about an hour later.The tv will be resetting itself back to the factory setting.Now the tv should be working again.If it still have the same problems.The tv have a power supply board problems.That the board,where the a/c power cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
SOURCE: how to connect a panasonic
What is the source? if you are using an HDMI connection from an HD source you should have digital audio. also, if you are connecting digital cable directly to the TV it will send digital audio out as well. check the optical cable at the amp end to see if it is working. it should glow red at the tip if it is.
there are digital input mode settings as well on some receivers. if it is set to DTS it won't work on PCM audio. if it is set to auto Digital it should work on any standard. check the PCM or DTS options in both the TV, and receiver if those settings are there.
