Display panel is flickering slightly dimly and clock won't keep time.
Usually this turns out to be a problem with the main clock/electronic control but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru ----- www.repairclinic.com
http://www.repairclinic.com/Maytag-Range-Stove-Oven-Parts
Yeah..it happened after we had a power failure. Once the power came back on, this was the issue.
