Adobe Premiere V 7.0 Professional for PC Logo
jovanni padro Posted on Jul 18, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Steps in making video karaoke using premiere 7.0
Hellow folks, Is it possible in adobe premiere 7.0 if I will make a video karaoke like i had with my cd because i wanna make my own video and put text on it that would look the same way a karaoke song render? I would like to know the steps in making them. Thank you and God bless...
Anonymous
Level 2:
  • Expert 100 Answers
  • Posted on Jul 31, 2007
Anonymous
Expert
Level 2:
Answers
100
Questions
0
Helped
29243
Points
214
I dont know if its possbile in Adobe Premiere, but I lately saw CD G application, I dont know how it helps, but it DOES help with karaoke stuff, if you want to know more about this application, and if you want further help, just chat with me live.
Can i use Adobe premier pro on my gigabyte desktop wiyh window 7?
Here are the system requirements for the latest iteration of Adobe Premiere Pro which is version 12.0. In fact, all versions of Adobe Premiere Pro for Windows after CS4 are 64-bit only
Which means you're out of luck if your Windows 7 is 32-bit.
https://helpx.adobe.com/premiere-pro/system-requirements.html
tip
Edit flip camera files with Premiere Pro
Overview of Adobe Premiere and Flip Camcorder:
Adobe Premiere Pro is one professional, real-time,timeline based video editing software application. Flip cameras store their video in a high-definition MP4 format. However, you will likely not be able to edit the video by importing it into Premiere Pro without converting it. The best solution to make Flip Slidehd/Ultra/Mino camcorder mp4 videos edit on Adobe Premiere Pro version 1.0, 1.5, 2.0, CS3, CS4 and CS5.
Best solution - Flip to Adobe Premiere Converter is a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG (MPE,MPG), AIFF, MP3, WAV, WMA, etc. Flip Video to Adobe Premiere Converter easily convert flip camera videos to Premiere Pro with no quality loss. Under the help of the Converter, you can import the output video and edit it in Premiere Pro with ease, no matter which Adobe Premiere Pro version you possess. Furthermore, it can also support you to import Flip video to Windows Movie Maker/WMM.
Guide to import/edit Flip videos in Premiere Pro with several simple steps.
Part One: Convert Flip Video to Adobe Premiere Pro Format AVI, MOV, MPEG etc.
Step 1: Load files
After download and run Flip to Adobe Premiere Converter, Press "Add File" to import flip .mp4 video to the program.
Step 2: Select the output format and its destination
Select the output format in the drop-down list of "Profile", like DV-AVI. Specify its destination when click the "Browse" button.
Step 3: Click "Convert" button to start converting flip camera video to target format.
After successfully convert Flip to Premiere Pro supporting formats, you can import the video to Adobe Premiere.
Part Two: How to import output video clips and other files into Adobe Premiere Pro?
Adobe Premiere accepts you to import a single video clip, multiple clips, or an entire folder of clips. You can also import a variety of audio and still image files, including sequences of images and layered Photoshop files.
Select File > Import from the main menu.
Tip1: To import a single file: Locate and select the file, then click Open.
Tip2: To import multiple files: Hold down the Control key to select multiple files, then click Open.
Tip3: To import a folder of files: Locate and select the folder you want to import, then click Folder. A new bin is created in the Project window, containing the contents of the folder.
Tip4: You can also import files and folders by dragging them from "Finder" into the Project panel.
Notes:
1.The pixel size of your clip cannot exceed 4000 x 4000 pixels.
2.If your imported clip appears distorted or stretched, its pixel aspect ratio may be set incorrectly.
Well Done. Enjoy Flip video editing in Adobe Premiere Pro with Flip to Adobe Premiere Converter.
Related: Flip camera review: The best flip camera after Flip Ultra, Flip Mino, Flip Ultra HD and Flip Mino HD.
on Aug 11, 2010 • Computers & Internet
tip
Edit Flip Camera File with Premiere Pro
Premiere Converteris a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG
Step 1: Load files
Notes:
on Aug 10, 2010 • Computers & Internet
My hyundai premier 99 karaoke player have audit but no video display.
First make sure your video cable is ok. If it is, there is a chip inside that switches video sources which can burn. Use the s-video output to get the video. Use an s-video to composite video adapter cable to match your tv if you prefer. The s-video output bypasses this chip.
tip
Overview of Adobe Premiere and Flip Camcorder: Adobe Premiere Pro is one professional, real-time,timeline based video editing software application. Flip cameras store their video in a high-definition MP4 format. However, you will likely not be able to edit the video by importing it into Premiere Pro without converting it. The best solution to make Flip Slidehd/Ultra/Mino camcorder mp4 videos edit on Adobe Premiere Pro version 1.0, 1.5, 2.0, CS3, CS4 and CS5.
Best solution - Flip to Adobe Premiere Converter Flip to Adobe Premiere Converter is a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG (MPE,MPG), AIFF, MP3, WAV, WMA, etc. Flip Video to Adobe Premiere Converter easily convert flip camera videos to Premiere Pro with no quality loss. Under the help of the Converter, you can import the output video and edit it in Premiere Pro with ease, no matter which Adobe Premiere Pro version you possess. Furthermore, it can also support you to import Flip video to Windows Movie Maker/WMM.
Part One: Convert Flip Video to Adobe Premiere Pro Format AVI, MOV, MPEG etc. Step 1: Load files
Part Two: How to import output video clips and other files into Adobe Premiere Pro? Adobe Premiere accepts you to import a single video clip, multiple clips, or an entire folder of clips. You can also import a variety of audio and still image files, including sequences of images and layered Photoshop files.
Why not download Flip Pro to have a try?
on Jul 20, 2010 • Cameras
How do s make a split screen in adobe premiere 7
select the clip,then right clich,then press unlink.
It will result in audio & video will be seperated
I can't figure out how to get adobe premier pro 7 to capture!
FIRST INSTALL ANY FIRE WIRE CAPTURING CARD & THEN CONFIRM THAT IT IS PROPERLY INSTALLED & HARDWARE IS DETECTED. AFTERWARDS WHEN U WILL ATTACH UR HANDYCAM WITH YOUR CAPTURING CARD YOUR CAMCORDER WILL BE DETECTED AUTOMATICALLY & THE WINDOW WILL OPEN & WILL ASK YOU THROUGH WHICH SOFTWARE YOU WANT TO CAPTURE THEN SELECT ADOBE PREMIERE THEN OPEN ADOBE PREMIERE GO TO FILE MENU & THEN SELECT CAPTURE THEN U CAN PLAY , REWIND OR FORWARD TOTAL FULL CONTROLL OF CAMCORDER WITH SOFTWARE ,TO CAPTURE CLICK RED BUTTON,IT WILL START UR CAPTURING,GIVE THE FILE NAME & DESTINATION WHERE U WANT TO SAVE THE FILE THEN START CAPTURING.
2helpful
Adobe Elements Priemiere 2 not running correctly.
With the description you've provided, the problem seems with the skype installation. Its possible that some of the lib/dlls were overwritten by the skype which were actually used by A.Premiere.
Now as you've uninstalled the Skype, try re-installing the Adobe Premiere and keep an eye if any issues comes.
And dont use skype in combination since seems they are not compatible and are using shared libraries.
Hope this helps.
Thanks.
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
