Sewing Machines Logo
A
Anonymous Posted on Jan 20, 2013
Stuck coupling knob elna - Elna Quilter's Dream 6003Q
Elna 6500 Sewing Machine. The reverse key only works sometimes. How do I fix this please?
Elna
Sewing Machines Plus https://www.sewingmachinesplus.com > Elna PDF Reverse Key. If you are sewing a straight stitch, zigzag stitch or 3 step zigzag stitch*, press and hold the key. The machine will sew in reverse until you.
76 pages
Elna sewing machine sews backward
Quiltingboard Forums https://www.quiltingboard.com > Main
Jul 15, 2019 - I think the lever above the stitch length knob is for temporary reverse. The knob has red numbers and black numbers. The red numbers are for ...
Missing: 6500 ‎ key
ERROR CODES
lesporteslogiques.net http://lesporteslogiques.net > materiel > Error-C... PDF With the machine off, hold down the Start/Stop & Reverse buttons, then turn the machine on. 2. Press 'Bobbin'. 3. Insert the red bobbin gauge. Press 'Key' until .
2answers
What can I do to fix dim display screen on my elna 9006
There may be an adjustment on the backlight display?
Do you have an Elna 9006 Envision manual?
How to get the needle to come up nothing will move on a 130 elna contessa
my sewing machine would do that from time to time, try turning the wheel hard enough to break the thread if it's stuck, if that doesnt work then try unscrewing the needle and turning the knob so that it lifts away from the needle then you can get a better view of whats going inside.
Coupling knob
try using one of those squares of gripping plastic mat that you put into the bottom of the drawer to get a good grip on the knob and outer flywheel. if this is an older Elna, then they can get pretty siezed up with age.
Hi, I have an Elna Carina and the flywheel is
I can direct you to a service manual for your machine but it may be something that you need a trained Elna service technician to deal with.
Link is http://www.arizonaexpressionz.com/elna_service/air_elec_carina_elec_SM.pdf
I am more familiar with the SU air electronic where you just hold the outside of the flywheel and turn the inside knob to disengage and rengage the clutch - didn't realise the Carina had a button flywheel release until I looked in the service manual.
Anyway, you could try dismantling the flywheel following the exploded diagram in the service manual if you are technically minded.
Or just take it to a reputable serviceman, I'm a big fan to supporting these guys as their knowledge is invaluable.
1helpful
My elna has cams to upgrade the number of stitches it can do but I am unable to get them to work. I believe I have installed them correctly but cannot activate them.
Throughout the Swiss Elna range there were several of their top of line models that have the black cams for additional stitches and they all have an "Elnagraph" device in the top of the machine case where you insert the cams.
There are single cams where the needle just moves ffrom side to side while the fabric moves forward. And double cams where the needle moves from side to side while the feed dogs move the fabric forward and backwards to get a combination stitch. The trick is to get the Elnagraph to engage so the arm in it can "read" off the disc.
There are a couple of other knobs that you need to adjust to get the cam stitch though.
Star Series: (white machine with blue top) you need to put the stitch selector inside the elnagraph flap to "A" on the Star series and then stitch width to 4 and stitch length to the red A zone.
Air Electronic SU or Carina: you have 3 knobs from left to right - stitch selector (put it on 7) , stitch width (put it on 4, orange area) and stitch length (turn it around to the orange zone for the automatic stitches).
And on the early Supermatic the adjustments are a little different again.
And ALWAYS turn the stitch width and length dials back to zero, before you change the stitch selector, or pop out a cam.
I hope this helps you get your Elna stitching from the cam, there is a great Yahoo group called Elna Heirlooms too where there are lots of knowledgeable Elna owners and some files listing all the cam stitches.
4helpful
2answers
Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
