Use a brand new needle that is best suited for the thread weight and type of fabric you are stitching. All About Needles
Be sure that you ALWAYS RAISE the presser foot when threading the upper thread. This releases the tension disk so the thread will seat properly. Also, if it continues to have loose stitches underneath, tighten the upper tension.
try adjusting the top thread tension and see if that help the loose stitches underneath. also try changing the needle and clean under the needle plate and in the bobbin area
change needle
change your stitch length dial to a number higher like if it on 3 change it to 4 or 5
change the tension to 3 or 4
clean under the needle plate where the feed dog is for lint
clean the bobbin area for lint or loose threads
rethread the machine
When you see loose stitches underneath your sewing, it usually means that the top tension needs tightening. Write down where your tension disk is before you turn to a higher value, then sew. Keep doing the above until you reach the correct top tension. The reverse of this would be loose stitches on top which means the bobbin needs to have the tension screw increased, little at a time, about 1/8 ". Sew and repeat until the stitches are equal.
Usually If the underneath is loose it is the top tension that is the problem. If it is the top stitching that is loose it is the bottom tension. Hope this helps.
Your top tensioner is too loose.make sure the thread runs through all the relevant eyes and then tighten the top tension little by little as you do a sample few stitches.
Sounds like your upper thread tension is too loose. Try tightening the tension on the top thread, but first, make sure the machine is threaded correctly through the tension disks.
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay. sewman7
ever tried adjusting the thread tension control? clean if possible tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
