This is an RCA 4 line speakerphone. I recently changed service providers and I can't get the blinking message waiting light to turn off. I cannot access the old voicemail to clear it.
I would even reset the entire phone to factory specs if that will clear the light. Any help?
Thank you!
The message indicator is controlled by a signal from the service provider; whether that be The Phone Company, a VOIP setup or your internal PBX. Try powering off the phone, disconnecting the phone lines and powering it on. At this point the light should be cleared. If that works, plug in phone lines one by one, waiting a while in-between, to see what line is causing the indicator to light. Another (inelegant) solution is a small piece of black electrical tape.
Unplug the phone from power for about ten minutes and see if that resets it..i'm not sure if that uses and adaptor for power... but be aware it also gets power from the phone line as well... so unplug that too.
Robert
Please take a moment to rate this solution.. thanks
despite the lousy rating you just gave me... what is the model number i'll try to locate the manual
Robert
Resetting it to factory default shouldn't hurt anything tho you will lose any stored phone numbers. it sounds to me like you are still getting the message waiting signal from the phone provider you had... has the switch been made yet ...?
if that works and i suggest it will .... please upgrade this rating to perhaps a fixya.... we are all basically volunteers... we get the warm fuzzy feeling from the ratings....
take care and let us know how you make out
Robert
are you removing the phone line when you reset it... the phone line has power (12 volts i think it is). also flip the phone over and see if there is a cover for a back up battery... there may very well be one to keep your numbers in case of a power failure.
Robert
my thinking is that the message waiting is turned on by a signal from the phone company when you have messages waiting... contact them and very forcefully ask them to clear those messages and close the mailbox.
Robert
Nor to me either... really dumb question but i have to ask... you have checked your current provider to see if you have messages... if you don't have a mailbox explain to them what is happening and see if it's an issue with them.
Other then removing the phone line... adaptor and backup batter for about 15 minutes i know of no other way to reset the phone.
Robert
thank you kind sir... beer actually works better for me but this is good... take care
Robert
I removed all power for 15 minutes and it is still blinking. UGH! LOL
Any other thoughts?
Thanks
Robert, I did not mean to offend you in any way. I am truly sorry and realize that you are just trying to help me that is why I said thanks for trying.
I have the manual in PDF format and have looked all through it and can't find anything to clear the light. There is a reference to resetting the phone to factory default. But I was not sure that would fix the issue.
It is an RCA 4-Line System Phone Model # 25414RE3
Any help is greatly appreciated and I will not rate this again until we finish ok? :)
yes, that is the issue. The other line is disconnected and was VOIP. It nor the router are still connected to the phone. So, it has to be something internal on the unit.
I will reset to factory specs now and see if that does the trick.
Again thanks for helping.
Well, that didn't work. It didn't even erase the stored speed dial numbers which is weird. I don't have a clue at this point. Here is what I did per the manual. 3 TImes.
Restoring the Default Settings
This feature allows you to reset the menu to the original factory default settings.
1. Press the MENU button while in standby mode.
2. Use the < REVIEW > button to scroll to RESTORE TO DEFAULTS.
3. Press the SELECT/SAVE button.
4. Use the < REVIEW > button to scroll to YES or NO.
5. Press the SELECT/SAVE button to save.
I reset the phone to org specs and wiped all memory, which didn't get rid of the light but erased all my speed dial numbers.
Is the phone receiving power internally even though it is unplugged? i.e., is there a small nicad battery powering it's memory like in a computer? Can't that be removed to reset the whole phone?
Thoughts?
the battery has been removed and the phone line. still no dice.
I did that and it was a no go. How could the phone still be receiving a VOIP signal for msg's waiting when I have disconnected their modem and installed a magicjack? It doesn't make any sense to me...
Robert, I don't either frankly. But you have been so nice to try to fix this for free that I will give you the highest rating so you get the warm and fuzzies. LOL
Best
Dan
Tried all these and more, RCA said to just buy a new phone.
Unbelievable.
Die, all you self-righteous hosebags, die!! Can't you make a product that works? Or at least support the garbage you DO sell?
This country's doomed. . .
