Sharp AR-5520N Logo
Anonymous Posted on Jan 20, 2013
Sharp photocpi machine ar5520d devloperisdamage after 4 days
DEVOPER IS WHITE AFTER 4 DAYS YA 500 COPY AND THAN COPY IS VERY LIGHT
Mahima mantri
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 04, 2021
Mahima mantri
Contributor
Level 1:
Answers
Questions
0
Helped
80
Points
9
Nice information. Check DevOps Classes in Delhi
Anthony Karuku
Level 2:
  • Sharp Expert 268 Answers
  • Posted on Jan 31, 2013
Anthony Karuku
Sharp Expert
Level 2:
Answers
268
Questions
Helped
104942
Points
615
The developer was improperly installed. Please install developer type sharp ar205dv.
3helpful
3answers
My sharp xerox machine AR-5516 is bleaking a man near toner signal point. why is this bleking? Kindly solve my problem.
The blinking man who we refer to as Mr Bill is a "time for maintenance light". Just ignore it, the machine will keep working.
Sharp MX 2300n - When I print or copy color, the whole page has a pink hue to it. Not there when printing or copying black/white. I have cleaned the laser holes and pulled the corona knobs several times,...
PRESS #*c* in your control console respectively then you will get a service mode,Check to confirm that there is A3 paper in the paper feed tray. If paper is insufficient, supply it, will ask for main code press 67 then press Start and machine will ask for a sub code press 24, then machine will give you another display press execute on that one, you will get a pattern print out. After completion of self-printing, the display is shifted to the output patch scan start standby screen. Make sure toplace the printed test pattern on the glass pointing the light side of the pattern towards the left hand side that is to place the light side coinsiding with the arrow marking on the glass table, place some white A3 sheet above this to correct the white value, press service and then press execute then machine will give you another print out then on that you press ok on that one and wait for the below display message.
PRINTER ENGINE HALFTONE AUTO ADJUSTMENT MODE
COMPLETED THIS PROCEDURE.
PLEASE QUIT THIS MODE.
After this press CA button on your console and check the copy, repeat the same procedure for 4 or 5 times if the copy quality needs to be get improved. Rate this and vote for this
My Sharp AR-M160 will print but not copy. No problem buttons are lit up but just dont work.
have you got the machine on print mode
if you find the button that says print copy fax on it press it until the light is on copy...
hope this helps
Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
Dear All We want to but sharp Machine but we ...
5316 ,16 copy per minute
5320 , 20 copy per minute
2answers
AR-5320 Black and White Copier: new 5320e no photocpies but print out blank paper...
hi dear may you dont have put the origenal document proper or may be blank, just put writing side down on the glass or if u are using ADF put the writing side up side,
thanks
1helpful
The technical manual all the new AR sharp
Please use the link below, all manuals casn be found in the drop down boxes.
http://www.sharp.co.uk/page/downloaddrivermanuals
Mr Sharpy.
Sharp AR-5320 B & W Copier giving L 4 error msg alternatly
L4 is main motor drive overload. It could be a power problem going on with the copier. Are these copiers plugged into surge protectors?
If you can have a Sharp technician look at it, it would be a good idea to determine if the motor, power supply, or main board is the culprit.
Sharp ar5320 developer reset code
The developer doesn't have a reset code.  It uses a calibration program instead with the reset integrated into it.
Even though the copy quality is fine for now, it can change in the next few days.  You should order some developer.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
