Just finished defrosting something and it entirely cooked the product and f-6 appeared on the screen and now I can do nothing
Self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "?" is displayed...
F6 ?Microwave Relay Failure: Check the microwave relay.
F6 showed up on the display after regular use of the microwave. After a few attempts to unplug and replug, the display could be reset. Is it safe to use the microwave now?
Please reply back with your brand and model number so we can help you.
Have you tried to unplug the microwave for about 30 seconds and then plug it back in?
