The printer will not print( only blank pages are being spurned out).
( it was working perfectly until this problem occured)
The printer ink is showing nearly full but the dianostic said it was empty so i put a new black and a new colour cartridge in.
Still didnot print.
Next I installed the programme again( after i first ubinstalled it)
Still not working -only blank pages again
would you advise me how to get it working again?
SOURCE: my kodak printer easyshare 5100 not responding
maybe..the scanning is most likely from something else..try new drivers first
http://tinyurl.com/6qcpgy
SOURCE: Kodak EASYSHARE 5500 will not print with black ink
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
SOURCE: Kodak EasyShare 5100 All in one printer
I just called them yesterday and a new printhead should be on the way
SOURCE: Kodak Easyshare 5100 All-In-One Printer
The Kodak printhead is known to dry out. You can call kodak customer
service and complain your printhead is failling explain you have run
the printhead cleaning many times waisting your ink. They should ship
you a new printhead and free inktanks.
or if you dont want to wait on the phone....
I
have found lysol hand wipes to work wonders on the kodak printhead. I
have an ESP 5 and I have wiped the printhead with a lysol hand wipe
many times and it works like new. Here is a link to the product.
http://lysol.com/products/disinfecting-wipes/dwipes-4-in-1/
To wipe the printhead follow these instuctions.
remove
the printhead from the printer. put the tanks back into the printhead.
Be very carefull not to drop the printhead and do not put the printhead
on a table with the nozzle plate down (where the ink comes out). take
the hand wipe fold it a couple times. Gently wipe the printhead nozzel
plate in the direction of the lines on the nozzle plate do not do a
circular motion or wipe against the grain. you may not even have to use
a wiping motion. you can just place the wipe on the nozzles and let the
printhead soak. this will clear up dried up ink and unclog the nozzles.
put the printhead back into the printer run one printhead clean once to purge the ink and try to print.
I hope this helps.
I
used my printer to do a photo guest book at my sisters wedding it
turned out great (i wipped the printhead before i started all the
pictures look perfect!)
SDtester.
exactly the same--help
Printer was working fine .... but suddenly stopped printing black. I had put a new cartridge in before Xmas but put a new one in .... uninstalled ... reinstalled ... ran a calibration check ... but it will not print black. The colour seems to be alright-ish but the colours are fainter than normal. Kodak despite their 24 hr reply system still has not answered after 28 hrs .. I need to print out my travel tickets for my flight! Help!!!
I am not getting anything on the page at all? Whats up with thi sdarn thing.... It is brand new and we have replace the ink way to muchm still programmed it, cleaned the print head, etc... HELP
i've changed ink cartridges and still not printing just faded black lines across page....it was working fine...then started playing up please someone help
