Question about Exercise & Fitness
Hi, I have a motorized treadmill JX-260E & it just won't start. It worked fine until yesterday, now when I turn it on it beeps & reads ERROR 9 on the screen. I don't know what this m
Hi, I have a motorized treadmill JX-260E & it just won't start. It worked fine until yesterday, now when I turn it on it beeps & reads ERROR 9 on the screen. I don't know what this means & I would really appreciate it, if you could tell me what it is or direct me to someone that can help. Nuala
    Master:
  • Exercise & F... Master
  • 165 Answers
Hi sir.
After reading his problem.
Please do the Maintenance and LUBE,
The error # 9 mean that thinking.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
How To Lubricate Treadmill
Posted on Nov 24, 2017
6ya staff
SOURCE:
Anonymous
  • 16 Answers
SOURCE: Need to put together a Nordic Track Elite 2900 treadmill.
Type into the serch, icon health and fitness, then click on the customer service, then click onto the manuals and the instructions should be in the owners manual.
Good luck.
Posted on Jun 29, 2009
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Posted on Mar 01, 2010
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: ProForm 530x Treadmill runs, but stops when I get on to walk/run
Unplug the unit and pull the motor shroud off and check the compartment it like sound you have dirt and corrosion . If you have a multi meter I'd start checking from the outlet and work my way to the lower board to see if I have power, Your question about the motor casing the problem fine the 2 leads that come form the motor and goes to the board pull them off (after unplugging the unit) and stick the leads into the motor connectors put meter on dcv and have somebody get on the treadmill and with one foot start pushing the belt . You should see dcv being generated for the if that the case then the motor by all rights should be good I would suspect that lower board. Hope this sheds a little light on the problem. Good Luck!!
Posted on Apr 11, 2010
Testimonial: "Very helpful! Thanks!"
outfield502
outfield502
  • 79 Answers
SOURCE: my treadmill motor starts exactly
that a qualified technician check the motor controller board the mosfet (IRF250N.) or diodes
Posted on Sep 08, 2010
Ishola Olayemi
  • 1196 Answers
SOURCE: when switching on my York
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful." Contact the business where you purchased your treadmill if repeating the calibration process does not result in a successful calibration.
Posted on Jul 17, 2011
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Image 10.2qi motor won't turn on. control board is fine and power is on.
1) Please test the main motor, see my personal TIPS for motor help.
2) test the output board for input voltage motor, if there are NOT the board is faulty.
see the diagram and block diagram
You can RUN the software calibration for diagnostic,troubleshooting, and fix it.
Happy NEW YEAR, God bless you
Dec 31, 2012 | Image 10.2QI/10.2Ql Treadmill Walking Belt
Macbook pro won't turn on
have you tried using a restore point? or resetting it to factory settings, although I wouldn't do that until you are left with no other options....You can try to call the company and see if they can walk you thru fixing it.
Oct 16, 2012 | Apple MacBook Pro 13
My new Bosch B26FT70SNS fridege which i got delivery yesterday morning compressor motor won't turn off. Since yesterday afternoon around 5pm until now 11am. More than 18 hours continue running, the...
HI JAMES.ummmm new bosh...should work.if not and motor running cont.then it sound to me like is out of refrigerant or motor faulty.check condenser unit.should hot.if cold call under warranty or replacement i would say.good luck Ali
Jun 30, 2012 | Refrigerators
I plugged it in and it will not start. It was working fine yesterday but now nothing.
Did it possibly blow a fuse in the treadmill? Also, Check your circuit breaker as well, and see if a circuit blew that was dedicated to the outlet.
Read the user manual of your treadmill to find the elevation motor. The treadmill fuses are located inside the elevation motor. If you don't have the manual, contact the manufacturer of the treadmill and ask if it can send you one or if there is one you can download online.
Turn off the treadmill and unplug it. If you have recently used it, let it cool down for one hour before opening.
Place the treadmill on its side and use a screwdriver to unscrew the lid off the elevation motor. Carefully remove the fuses. Some treadmills have easy access to internal parts where you don't need a screwdriver. If this is the case, simply lift the lid off.
Take the faulty fuses to a hardware store to make sure you purchase the correct replacement fuses.
Insert the new fuses into the elevation motor and close the lid. Plug in the treadmill to see if it works.
Sep 06, 2011 | Sears Exercise & Fitness
Beeps when buttons pushed, but won't start
Dear Sir:
Try it with some little Inyection of 50% of Oxigened Water +50% ethilic Alcohol(100%) for to clean the contacts or pad for the buttons.
Wait for 15 minutes.
An try it again.
Now if doesnot work go to the 2 Step.
2) You must open the cover, and look for the rely for to clean it contacts, in the same ways.The rely is the element for to swith off -and on the motor for Theadmill.
Respond it if you get solution.
sincerely.
E.Cuadra
Sep 05, 2011 | ProForm 980 CS Treadmill
My treadmill will light up an make a beeping nose when a button is pushed. The treadmill is pluged up and the red cord magnet is on when the buttons are pushed. However it just does the same beep for...
If the screen is lit and the screen shows that the belt is moving then it’s the motor controller. If the screen does not show that the belt is moving then it’s the console.
Oct 20, 2017 | Horizon Fitness T82 Treadmill
'04 Kymco Venox won't start. Bought it a few months ago from someone w. about 20,000 miles on it. Always runs good/never had a problem w. it 'til yesterday. Ran outta gas on the road...put more...
Hi Mrcherry99, for this situation I would call my local dealer or reputable shop's service department and inquire about any possible quick fix. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if possible, and give you a written estimate of repairs and answer any specific questions you may have about your issue. Good luck and have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 18, 2011 | 2005 Kymco Venox 250
Your Problem: jazfit-750 Treadmill motor will not turn on
DEAR
AT FIRST YOUR MOTOR CONTROL BOARD IS DAMAGE
I can turn it by hand it turns smoothly and the tread moves fine and the belt from the motor to the tread is good
Mar 18, 2017 | Exercise & Fitness
Exercise & Fitness Logo
66 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
