Elmer, If you remove the gun assembly from the machine, if the machine is now not feeding wire, the problem is most likely the gun trigger is faulty. The switch contacts heat up and start sticking over time. If able too disassemble and clean trigger contacts. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." CRAFTSMAN 934 205111 Operator Manual commin problem with wire feed welder Wire won stop feeding
probably over heated and blew the reset button
100 amp welders have a duty cycle ( time in actual welding use ) of less than 20%
that means for welding for five minutes you have to let it cool down for 20 minutes
the lower the amps the longer you can weld for
beware tat the total amperage of the welder does not mean that you can weld for a long time at that amperage
on the plate on the welder is the duty cycle and you have to be aware of it or the machine will shut down
the numbers indicate ita a craftsman 180 amp welder bue one number is offf os it could be a plasma cutter and it is listed as a sears 180 amp plasma cutter. go here to look it up. Craftsman Tools www.SEARS.comFind Craftsman Tools & Tool Storage at Sears®. Shop Online Now!
I just checked it and it looks like most of teh parts for it are obsolete. They do not offer an owner's manual. I checked for both since you did not specify which "manual" you need
I think most of the older Craftsman welders were made by Century which is now owned by Lincoln Electric Company. If this is a wire feed welder you adjust the wire feed speed so that the arc sounds like eggs frying, the voltage setting (if any) will depend on the thickness of the material you're trying to weld. If it's a stick welder there will just be a current range control that you set depending on the thickness and type of material you're welding.
