Sanyo DP46849 46 in. HDTV Logo
VITO CALEONE LAPORTE Posted on Jan 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why my 42" sanyo DP42841 HDTV LCD SCREEN GOES BLACK ON THE LEFT SIDE?
THE SCREEN GOES BLACK AFTER TURN ON, THEN AFTER 20 MINUTES OR SO, THE TV WORKS RIGHT
Back2life Electronics
Level 3:
  • Sanyo Master 933 Answers
  • Posted on Jan 20, 2013
Sanyo Master
Level 3:
Answers
933
Questions
6
Helped
274336
Points
2189
That sounds like a faulty LCD panel tab. The only true fix is to replace the screen. This usually isn't cost effective.
5 Related Answers
Anonymous
  • Posted on Jan 24, 2008
SOURCE: HDTV 42 inch Plasma Sanyo model DP 42746
the picture is very dark
Anonymous
  • Posted on Jun 12, 2009
SOURCE: Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Justin Smith
  • 135 Answers
  • Posted on Aug 23, 2009
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
Anonymous
  • 183 Answers
  • Posted on Feb 28, 2010
SOURCE: My new Sanyo HDTV LCD won't come on, although the on light is on.
If your Tv is in warranty or you have a cover plan, you need to return the Tv for repair or replacement.Your Tv sounds like it has a power supply fault.
Chi Chu
  • 8457 Answers
  • Posted on Apr 02, 2010
SOURCE: Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
1helpful
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
1helpful
Turns itself off after being on for a while,but after about 20 seconds it comes back on automatically. I have a LAVA preamped antenna hooked to it. Is it the antenna or the analog board?
Try to set it up with no antenna, just the cable or wire as an antenna for a broadcast station. If you can just get 1 station then you can find out if the TV is turning off or the LAVA antenna.
If it goes out and comes back on it could just as easily be the power board.
Don't open it up yourself, there are hazardous voltages even with the TV unplugged!
I have a Sanyo 42" LCD tv model DP42649. The
The problem i'm having is, when you turn the tv on it has a split screen with the left side shaken off a little bit. if you give it a tap on the left side it will flicker and the whole screen will come on.
11helpful
4answers
Screen goes black, still have audio
I first changed the 220uf capacitor with no luck. I flipped the BURN switch to on and the set has been working great for a week now. Daughter left it on for about 20 hours overnight with no problem. Anybody have an idea what those 4 tiny switches are for? I have heard these type of switches called "dip switches". They are tiny white switches in a yellow block on the lower left side of the upper circuit board. The top one was labled 40", the next one down was labled 46", the 3rd one was 4 letters "EW" something I think, and then the bottom one was labled "BURN".
2helpful
42 inch lg tv powers on,goes off after about 30 seconds
hello my friend you have some loose connections on the digital board.this board is located right in the top center of the tv.if you do not have repair skills call the repairman he should not charge you too much for this job. good luck
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
