Ineed to rewire this freezer
SOURCE: TRUE freezer model number GDM-49F.
Your unit should have a defrost timer.The timer may be stuck in a defrost.It should be located at the bottom of the unit next to the compressor.Open the door to the timer and observe the position of the timer.If you turn the knob and the unit starts up,it's the timer. If this is the case, you can purchase a new one at any local a/c supply.Let me know,Mike
SOURCE: I NEED A DIAGRAM FOR DEFROST SWITCH ON T-72 F TRUE FREEZER
Go to www.truemfg.com and it will take you to their web site. They have a 24 hour, ask a tech a question. I could not find any wiring diagram on your particular unit but maybe they can help you via their tech hot line.
Good luck and hope this helps.
SOURCE: need wire diagram how to install 3 N 1 start relay
The two stripped black wires connect to power.
Black tabbed wire to common.
Red tabbed wire to run.
White tabbed wire to start.
Looking at pins on compressor, read like a clock. Common clockwise to Start clockwise to Run
SOURCE: I need to replace my
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
SOURCE: TRUE T-49F FREEZER DIAGRAM REQUIRED.
http://www.pdfdownload.org/pdf2html/view_online.php?url=http%3A%2F%2Fhvac%2Dtalk%2Ecom%2Fvbb%2Fattachment%2Ephp%3Fattachmentid%3D129111%26d%3D1285929051&images=no
