Cameras Logo
A
Anonymous Posted on Jan 18, 2013
Minolta AF 28 -135 repaur - Minolta Cameras
CL) U) 28-300/3.8-6.3 AF MINOLTA what camera will this fit
Sony bought out Minolta and a lot of the old type Minolta lenses will fit on Sony cameras but not all of them.
1helpful
Need manual for Minolta AF/2 projector
While I have not been able to find any listings or a manual for a Minolta AF/2 PROJECTOR, there were many Minolta AF/2 CAMERA choices available when I searched Google - everything from a uTube video to copies of paper manuals. I wondered if this was posted on the PROJECTOR board in error....
2answers
No Manual--Don't know what top buttons do Minolta AF 10
Hi, Do you still need help? I can email the instructions. Tony
2answers
Minolta SLR Lens on Sony - Does it work.
As I understand it, Sony bought Minolta, lock, stock, and barrel. Theoretically the lenses should fit and may work on manual, but I'm very sure they will not totally work on sony digital cameras. I wouldn't even try to fit them as the autofocus system on the camera may be damaged.
Looking for Digital Camera to use lens
Your Minolta QTsi Maxxum takes a Konika Minolta AF lens. These lenses work on these Konika Minolta DSLR cameras:
DYNAX 5D / Maxxum 5D
DYNAX 7D / Maxxum 7D
Used on a Minolta Maxxum 800 si
Hello
The Minolta AF lens will fit and work on most of the Minolta AF bodies (it will depend on exactly what lens it is as to the compatibility), you will also find that it will fit and work with the new range of Sony
digital SLR camera bodies.
The Quantaray lenses are a little bit more difficult as Quantaray make lenses for several different types of camera body, it should mention on the lens what make the lens mount is for. If you post further information about the lenses it might help.
Sony A100 compatibility
It would help if you actually gave details of the lens!
All the old Minolta AF and MF lenses will fit the Sony A100, but only the AF are auto-focus compatible.
Since the Maxxum 7000 was an AF camera, I would image that that is an AF lens pictured on the front.
Check out this site for more details:
http://www.mhohner.de/sony-minolta/lenses.php
Matt
3answers
QUANTARAY FOR MINOLTA AF 70-300MM compatibility
Usually mounts are unique to a camera manufacturer. There are exceptions. Sony has the Alpha; lenses for the Konica-Minolta are the same mount. Your AF (autofocus) lens will work on it. You might also consider picking up a Konica Minolta 5D or 7D.....they're no longer made and hence are cheaply had.
The MD and Rokkor lenses won't work on the Sony Alpha.
THIS IS A CHEAP LENS (<$50 VALUE) SO I WOULDN'T LET IT DRIVE YOUR DECISIONS!!
Top Minolta Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Minolta Camera Expert? Answer questions, earn points and help others
