SOURCE: Bose 901 connection to Pioneer VSX-917v Receiver
any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
mark
SOURCE: How to connect 901 equalizer to a Pioneer VSX 47TX
I have a VSX-36TX so this is how it's going to work...
You will need a separate stereo amplifier for the 901's to accomodate the need for the Active EQ. There is no way to separate your receiver's front L&R channel preamplifiers from their amplifiers.
I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds. You would probably just get a nice 2-channel amplier for the 901's. However, the VSX 47TX doesn't provide power for a Subwoofer, should you decide to get one, so you would need another amplifier channel for that, too. Therefore, you might look around for a powerful 3- or 4-channel amplifier so you could drive the Sub, too.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Not what you might want to hear but 901's have special requirements. I've had mine for 25 years and have no regrets.
A separate subwoofer channel on the amp could be used. Just run a single RCA channel from Sub OUT to one available channel IN on the amp and attach the subwoofer to it. Two would work, also. That's what I do. You could use a 1-2 RCA splitter to feed two avaailable channels on a 4-channel amp. The iterations are many. Have fun.
SOURCE: bose 901 equalizer hookup
I had the same problem- I have a Pioneer VSX-518 and Bose 901 series IV. My receiver has no "Tape Monitor", so after trying different hook ups, I went and bought a "3 input video switcher" (about $10.00) I run my STB (cable box), my PS3 and my computer through the inputs of the switcher (just the audio L/R) then the output to the Bose EQ input, then from the Bose EQ output to my receiver input (I chose to use the TV/DVR input). Now I just have to select which source I want to listen to from the switch, make sure the receiver is set to TV/DVR and I have fantastic sound via my Bose 901s. With this hookup, I have my 3 componets video connected to my HDTV via HDMI cable. It works for me. Hope this helps.
SOURCE: I have a new Pioneer vsx-1020 receiver for a new
check the impedence of your system and your speakers. if they are both the same e.g. 8Ohm then there should not be a problem.
your sytem looks on the web 110 Watt - 8 Ohm - THD 0.05 % - up to 7 channel(s) ( Surround )
and your speakers are also 8 Ohm normal impedence.
I would connect and put the volume down to zero and slowly increase volume to ensure not problems.
i hope this was useful.
SOURCE: how to connect bose 901 speakers to a pioneer
You want them to be your Main Front speakers, right? The news is not good.
There will be some limitations because you can't extract a 'processed' Front L-R from this receiver. The following will give you good stereo and Front L-R from the 901's but it won't allow central volume control or send them any of the DSP effects you may select. Sorry. If it had a Front L-R Pre-Out you'd be good to go for all functions and listening modes.
You'll need a separate stereo amplifier WITH ITS OWN VOLUME CONTROL for the 901's to accommodate the need for the Active EQ. Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
With this receiver we have to cheat to get the Front L-R signal out to the 901's (but it's unprocessed and at a steady MAXIMUM volume level)...
For connection I would run a pair of RCA cables from the VCR/DVR Audio Out L-R OUT jacks (*) to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp.
* You'll lose the ability to use these jacks for anything else, but few of us use them anyway. DO NOT select this function for monitoring or you lose all audio in the VSX.
Testimonial: "thank you . . great help and quick"
