SOURCE: amana furnace
This is no doubt due to failure of the "hot surface ignitor". This device lights the main burners for your furnace, and they fail a lot. I strongly recommend the replacement should be done by a technician.
Ray
SOURCE: My Amana Gas Fired Air
If you can look into the viewing port and see if there is a light blinking write down how many times it blinks. Next remove the access panel from the furnace. On the wiring diagram, you will find a diagnostic code chart. Match up the blinking light to the chart and it will give you a starting point.
SOURCE: no power to ac indoor fan motor
sounds like you might have a bad control board. try putting a jumper wire on the control board low voltage terminals R and G your fan should come on and run if you have 120v power to fan motor. double check that you do have 120 leaving board and going to motor. if no 120 bad board if you do have 120 bad motor. if it is the board it likely has a bad blower relay which is common in amana models and goodman equipment.
