We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa:
http://tinyurl.com/yzjozkThere should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. It will help you test the keypad with your meter.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
http://tinyurl.com/gv383If you'd rather have us fix it for you, we do that for $39.95 plus parts.
DISCONNECTING THE KEYPAD1. Be sure the oven is disconnected from the power line while you are taking it apart.
2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
4. Then the keypad strip will lift out. Clean both sides of the end of the strip with alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip. (A pencil eraser is better and safer).
5. Put the keypad strip back in, making sure both sides are down fully.
6. While holding the strip down, push the connector back down to lock it.
7. Try the keys again with the door closed.
We're happy to help and we appreciate your thoughtful rating of our answer.William E. Miller, AS-EET
[email protected]http://www.microwavedisplay.com
