I am getting an error code when trying to set up my new router
What to Do:
Navigate to the Wii Menu by pressing the HOME button on a Wii Remote and selecting "Wii Menu."
Look at the date and time displayed on the Wii Menu and ensure they are correct. If incorrect, they will need to be changed in order for you to complete the PIN reset process. You will not be able to reset the PIN until the date is correct. How to
Select the Wii Options icon in the lower-left corner of the Wii Channel Menu.
Select "Wii Settings."
Click on the blue arrow to reach the Wii System Settings 2 menu options.
Select "Parental Controls," then "Yes."
Enter your PIN or select "I forgot."
Answer your secret question or tap "I forgot."
If you know the answer to your secret question, enter it to unlock parental controls. The system will go to the change parental controls screen and you will be able to change your PIN.
Be sure to enter the secret question exactly as you originally typed it, as the answer is case sensitive.
If you don't know the answer to your secret question, tap "I forgot."
The screen below will appear.
Make a note of the inquiry number displayed on your system. You will need it to reset your PIN.
Click here to reset your Parental Controls PIN.
An e-mail address is required to use this service. If you are not able to provide an e-mail address, please contact us for additional assistance.
for more help visit CBR Tech Solutions
SOURCE: reset wii console
Step1First you will need to check a few things, just to make sure what the actual problem is.
*Check to see that all cords are properly plugged in.
*Make sure the sensor bar is properly center above or below your tv set.
*Make sure that nothing is blocking the signal to the sensor bar.
*Make sure that the batteries in the remote are in good working order.
*Make sure that there are no wireless devices close by that might be interfering with the signal.
Step2If after all this the remote is still not working then it probably needs to be re-synced.
Step3Turn off and unplug your wii console for a few minutes.
Step4*Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
* Then remove the battery cover from the wii remote, inside you will see another red button.
* Press and release the red button, the blue lights on the remote will start blinking.
* Quickly press and release the red sync button on the wii console.
* The remote will stop blinking and it should now be synced.
SOURCE: Brand New WII Console won't read any disc's
If Wii gives Disc Read Error, first step you need to check is to try
another disc or clean the exisitng disc. This will confirm that problem
is with either Wii or Disc. If the console itself is giving disc read
error then it needs to be repaired. You may check out DIY Wii Fix Guide,
that will show step by step information to fix the problem yourself. It
also gives information on fixing many Wii Related Problems, so its a
kind of Wii Problems Reference Fix Guide.
SOURCE: I'm trying to connect my Wii to the wireless
Greetings,
Please go through the Website link mentioned below.
http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterTroubleshooting.jsp
Please let me know if you have any issues.
Regards,
SOURCE: wii finds my wire-less router and puts it up on
SOURCE: error code 51420 on my
Error Code: 51420
The Wii console is not able to connect to your wired router or modem.
Power on your Wii
console and press the A Button on the Wii Remote to reach the Wii main menu.
Use the Wii Remote to select the "Wii" button.
Now, select
"Wii Settings" to access the "Wii System Settings" menu.
Using the arrow on
the right side of the screen, scroll to page two and select
"Internet."
Select
"Connection 1: None"
(Don't see
"None" in Connection 1? Click the Connection 1 button, then choose
"Clear Settings.")
Click on
"Wireless Connection" and then "Search for an Access
Point."
(Are you using a
wired Internet connection to your Wii console?
Select
"OK" and the Wii will display all the wireless networks it finds.
Select the wireless
network that is yours.
If you are prompted
to "Enter the Password or Key," then the wireless network you are
trying to connect to has wireless security turned on. You will need to type in
your security key or password and select "OK."
Select
"OK," "Save Settings," and then "Yes."
The Wii console will
run a connection test with your wireless network when the test is completed.
You should see the following screen:
As long as you see
"The connection test was successful," the "Wii Support
Code" does not matter and can be ignored
The connection test
was successful - Then you're almost done! After your connection test, the Wii
console will check if there is a new Wii System Update available. Once you
select "Yes" and "I Accept," the Wii will begin to download
any available updates. Click here to find out what's next!
The connection test
was not successful - If the test was not successful, you will receive an error
code.
Error Code 51330 or
52130: This means the security code you entered into the Wii is not the same
one your router is set to. Look in your router's settings and try again.
As a last resort...
1. reset your router or 2. temporarily remove the password from your router...
this way you will know where the problems lies.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
If you get an error code of 32002 on you Wii console, this indicates a problem with your Wii communicating with your wireless router.
There are a couple things you can try/check to help fix this problem:
1.Try using a different channel on your router and update your Wii to take to the router on that channel.
2.If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
3.Make sure the MTU values on your router match those entered on your Wii.
Also note that if you make changes to your wireless router and you have a computer that uses that router too, you'll need to update your computer to match the new settings on your router.
