You have to reset fuser errors with simulation 14. SM 5-1 should turn the lamp on. If lamp blinks on and off it is the
thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE*** You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser. SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
replace.
You can't post conmments that contain an email address.
Hit Pound, star, C, Star
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston. Skelton Business Equipment Houston Copiers
The error code F1-15 means that the stapler is not in home postion. It can also, be that the exit tray is not in "HP" aswell. I would turn the copier off and turn it back on and not use the stapler funcation. To repair the problem, there are a bunch of up dates to resolve this problem. I would change the out put tray from the finisher to the left out put tray... Good Luck
Yes, it is possible. You need to use the software for your Sharp copier to scan the colored picture. Once you have scan it, you may use or send it to any email address.
