Last time I bought Lucent CellPipe 50AS modem from a second hand. Unfortunately I'm not able to configure it, because default Full Access password (e.g. Xavi7000, Ascend, admin, ... ) don't work. I checked by telnet that all setings are blank (e.g. LAN address is 0.0.0.0, connections blank, etc.). So it seems that Full Access password was sent, but I haven't got it. Could You help me to reset password or whole device to factory settings to be able to configure me CellPipe50?
_______
Best Regards from Poland
Mirek
SOURCE: password recovery steps for lucent dsl max 20 dsl terminator
You have been prompted for the login password and received the following message: “Login Password isinvalid”.• Re-enter the correct password and press enter. Remember that the password is case-sensitive. Check that youare entering admin in lowercase and that the Caps key is not active.• If you have forgotten the password, you must reset the login password. Refer to the User Guide, ChangingConfiguration Switches, and perform the following procedure:1. Move switches 5 and 6 down.2. Type login <newpasswd>. Password checking is overridden.3. Move switches 5 and 6 up.4. Complete any configuration update that caused the prompt for login.5. Change your login password to a new password.6. Store the configuration and reboot the router.Note: If you have not reset switches 5 and 6 to the up position and have rebooted, this will place the router inmaintenance mode. Set switches 5 and 6 up and turn the power off and
www.alliedtelesyneurope.com/media/.../manuals/rg624-34_um_a.pdf
