NEFF integrated dishwasher - does not start up - has been working but suddenly stopped (before the machine went through the cycle)
have tested by pouring water down it, checking outflow is not blocked, that the machine is plugged in and that the lights are working on the top...
What your saying is suggesting a water supply issue. The Model number you've given can not be found on the Neff website.
You will need to disconnect power, turn the water supply off (under sink or behind dishwasher), disconnect the water line, put the end of the hose in a bucket or cup, turn water back on slowly and make sure water flows. Turn back off. If water flows -
Then check that there is not a restriction in the water solenoid valve. If you know how to use a multimeter, check the water valve solenoid for continuity.
Plug the unit back in, and initiate a wash cycle, and watch for voltage applied to the water solenoid valve. If you get voltage, you should hear the valve open.
Power the unit off, connect the water line, and repower the unit. Check again if water does or doesnt flow.
Let me know what you find.
thanks unit has no timer - and we did try and fill up to check that the water supply was not the issue - but as far as we could tell that did not work (assuming we did it right that is!)
for a 5946 NEFF 45cm intregrated dishwasher...
If this unit has a controller board, as opposed to a timer, it may be a bad controller board. If it has a timer, can you rotate the timer manually and get any action to occur?
It could also be the fill solenoid or water supply. Sometimes the timers or controllers don't advance until they know there is water in the unit.
Please reply to clarify.
