RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Shakeela Cornelius Posted on Jul 13, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RCA 52inch TV
The color is all green and you can see green lines going across the TV. They are kinda of bent.
Anonymous
Level 2:
  • Expert 398 Answers
  • Posted on Jul 13, 2007
Anonymous
Expert
Level 2:
Answers
398
Questions
0
Helped
214407
Points
960
If the screen control for the green picture tube is set too high, then the colors will be greenish, there will be green where there should be black and there will be fine curved lines (retrace lines) in the picture. If you feel confident then you can open the set and look for the focus block which has the 3 focus and 3 screen controls. One row is labeled Screen and the green control will be the center one. Try turning that control down a little and see is the green background and curved lines go away. If they do not go away then there is something more serious wrong. If you do not have experience working on projection sets then allow a qualified tech to handle it for you.
When i go to turn on TV the green light blinks 3 times and that is all it does- its an rca 52inch projection
You have lost the high voltage section and the high voltage module will have to be replace or repair, and you are looking at around 450 on repairs.
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
2helpful
My RCA 52inch DLP TV has 5 blink red lights and is making a loud buzzing sound. I am pretty sure it's the color wheel, but from your experience, could this be it?
the loud buzzing could mean something is stuck in the color wheel or that it's shattered. Either way, you're going to need a new color wheel, I agree.
I have a 52inch rca projectin tv model hd52w59 i
Ur convergence it dead,U know how to solder?Buy a covergence kit,replace what in that kit.Tries these Websites,Tv Repair World.com,Ebay.com.
1helpful
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
1helpful
The tv screen is green
This is usualy a bad picture tube. are there any bright lines running across the screen? It would be helpful if you could give the brand and model number
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
