Computers & Internet Logo
melanie jaeger Posted on Dec 01, 2017
Ihome keyboard not picking up most of what I type
Brand new, mouse works perfect. The keyboard only works 50% of the time, backspace-ing is the worst, I tried moving the receiver to a different usb, all the keys stop working randomly until I click outside of the text box & then back on it again, so frustrated please help, I dont think its the batteries its brand new
5 Related Answers
Anonymous
  • Posted on Feb 07, 2008
SOURCE: acer keyboard messing up
Fantastic! I was just having the same problem when I read this article and pressed FN+NumLk(F11), then the keys started to work properly again.
Anonymous
  • Posted on Nov 19, 2008
SOURCE: Logitech LX310 keyboard / mouse (wireless)
it works fine on my brothers computer but it doesnt work on mine, i dont really want to reformat either. any way of fixing it without reformat?
Anonymous
  • 8637 Answers
  • Posted on Jan 20, 2009
SOURCE: Wireless mouse not picking up
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Anonymous
  • Posted on Apr 10, 2009
SOURCE: Cordless Desktop EX 90 Mouse Not Working
I took out the batteries from the Logitech cordless mouse last night, and when I put them in this morning, the mouse does not respond.  Pushing the connect button on the receiver does not seem to help.  Ideas please?
Anonymous
  • Posted on Jul 20, 2009
SOURCE: MX600 Logitech laser cordless mouse, left button stops working
Just found a temporary solution (fixes the immediate problem, but it does return):
Turned the mouse off held down both buttons, turned it on, let go of both buttons. When you let go, it works again.
Space bar, left-side enter key and backspace do not respond.
Try buying a can of compressed air and cleaning around those areas if you have spilled liquid on them ,that could be the prob as well
Keyboard does not always pick up letters I type.
This may or may not be a solution but 1 try putting brand new batteries in the mouse and keyboard and move all cellular and cordless devices away from the computer. Other than that see if there's a coloration between how much is going on in the PC (like how much cpu\ram\disk reading) and the times when the pc doesn't pick up the key strokes. Lastly is the keyboard clean?
I just purchased a Microsoft Media Desktop 1000, and the backspace key does not work.
If it's brand-new, and all of the other keys work, then the keyboard is faulty. Call Microsoft and order a replacement.
3answers
Firstly, try changing the batteries in the keyboard.
If still has issues, try moving the receiver to another area. Try to remove from other sources of interference such as Monitors, Speakers and Power Supplies.
If this doesn't work, try using a non-wireless mouse, and see if the keyboard still has issues.
If all this fails, then I would consider replacment.
LX7 optical mouse
Is your back button stuck under the left click button? Mine did this, simply pry up on the let click button and it will release.
2answers
GE Wireless Keyboard - intermittent keys
I would be more inclined to think that its a mechanical problem. You didnt indicate how long youve been using it or how heavy a hand you have while typing but I think its probably a safe bet that the keyboard hasn?t worn out from use. I have had problems with lightly constructed plastic keyboards that are slightly bowed or warped in spots. The keys dont always make a connection with the contact below so your keystroke isn?t registered. Warped areas can easily extend over several keys, thus your clustering. If this is the case there really isn?t much you can do to repair it other than call the manufacturer if its still in warranty. If not you can experiment, perhaps there is some extra plastic in a critical area that wasn?t removed. Be warned though, not many keyboards these days are designed to be taken apart and reassembled easily.
Top iHome Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
goneforever.
Are you an iHome Computer and Internet Expert? Answer questions, earn points and help others
