I don't have the original remote. the tv screen reads "ant channel 4. i want to re-progam to cable. do i need a remote to access menu, or can i do this manually? mine is lost, but i have a "all in one" model urc 3050B00. or do i need another universal remote? please help. [email protected]
SOURCE: manual menu w/o remote
no I'm afraid there is no way to do this without the original remote. You can get an original replacement rempte HERE: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=CXM1374&brand_pn=SAMSUNG_CXM1374&mode=large&uid=11826052948280 Good Luck
SOURCE: Teaching a Universal remote w/o the original
use the menu button on the tv. you dont need the remote.
SOURCE: Programming Code for a Toshiba dvd/vcr on a Samsung BP59-00048 universal remote control
If you haven't found the manual yet, you can download it from samsung.com's download center. Just enter your model number or search by product category.
SOURCE: remote tv control
http://www.scribd.com/doc/2304654/Samsung-HPS4253-Manual
page 43 and 47
cheers
Richard
SOURCE: problem with HL-R6167W green vertical lines
You need to do an aggressive reset on the TV. This solved problem
completely for me. You must unplug the TV when it is on. Repeat this
several times until the TV is jolted back into the factory default
settings. The issue is actually with the programming I believe. The
clue was that the display worked 100% perfect in HDMI mode, and the
problem only existed in the cable setting, no matter if wires were
attached or not.
Again, do an aggressive reset to the TV by unplugging it several times
while it is on. It may not register the reset at first because after
all, the actual problem is a programming issue and it's having trouble
recognizing commands in the first place.
Good luck!!
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
• You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
• If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
• If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
• To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
• Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
1 Find and disconnect the cable that is connected to the
ANT IN terminal on your cable box.
? This terminal might be labeled "ANT IN", "VHF IN" or
simply, "IN".
2 Connect this cable to a two-way splitter.
3 Connect an Antenna cable between an OUT terminal on
the splitter and the IN terminal on the cable box.
4 Connect an Antenna cable between the ANT OUT terminal
on the cable box and the B-IN terminal on the RF(A/B)
switch.
5 Connect another cable between the other OUT terminal on
the splitter and the A-IN terminal on the RF (A/B) switch.
6 Connect the last Antenna cable between the OUT terminal
on the RF (A/B) switch and the ANT IN (AIR/CABLE)
terminal on the back of the TV.
After you have made this connection, set the A/B switch to the
"A" position for normal viewing. Set the A/B switch to the "B"
position to view scrambled channels. (When you set the A/B
switch to "B", you will need to tune your TV to the cable box's
output channel, which is usually channel 3 or 4.)
OK
